编辑简介: |
ECOFAST system ?Distributed installation technology in IP65 ECOFAST (Energy and Communication Field Installation System) is a system solution for distributed systems outside the control cabinet. It sets new standards in equipping machines and plants for automation, low-voltage controlgear and drives.ECOFAST is centered on the extensive distribution and modularization of installations, combined with comprehensive diagnostics down to the component level. Modern field and power bus technologies open up new possibilities for machinery and plant construction. Systems of distributed design are flexible and can be adapted to the various requirements of industrial automation. This gives rise to advantages in terms of overall process costs. The standardized distributed installation technology with a high degree of protection (IP65) produces savings during ?Configuration, ?Wiring, ?Mounting, ?Start-up and ?during normal operation
