具有远程访问功能的模块化数采
具有远程访问功能的模块化数采
2020/11/17 18:48:27
Modular Stand-Alone Data Acquisition with Remote Access Capabilities
| Choose your Data Logger
| Choose your Signal Conditioners
| High Voltage Accessories
| IPETRONIK System
| IPEmotion PC DAQ Software
• Live Measurements
• Calculated Channels
• Post Processing & Analysis
• Configuration of IPETRONIK Hardware
• 3rd Party Support
| IPEcloud
• Fleet Monitoring
• Automated Reporting
• Live Remote Data Access
• Remote Reconfiguration
| Vehicle Bus & ECU Access
•  OBDII | SAE J1939 | WWH-OBD
•  Seed & Key XCP | CCP UDS ISO 14229
•  CAN | CAN FD | Automotive Ethernet | FlexRay
| Sensors and Accessories
• 3rd Party Support Cameras (IP and USB) Audio
• CAN Sensors
• Low-and High-Speed Signal Conditioners
带有高压充电桩的气候声学室
如何监控电动车充电桩能耗?
车队试验的远程实时显示方案,你了解多少
汽车娱乐系统解决方案
Capture Modules-车载网络报文捕获模块
