使用 YoctoProject集成Qt6
By Toradex胡珊逢
在嵌入式领域中 Qt 作为普遍选择的 UI 方案目前已经发布 Qt6 版本。本文将介绍如何为 Toradex 的计算机模块使用 Yocto Project 将 Qt6 集成到镜像里。
首先根据这里的说明,准备好 Yocto Project 的编译环境。这里我们选择 Toradex 最新的 Linux BSP V6 为例,其基于 kirkstone 分支,这也是一个 LTS 版本。
进入 layers 目录,使用下面命令下载 Qt6.4.3 版本的 meta-qt6 文件。
git clone -b 6.4.3 git://code.qt.io/yocto/meta-qt6.git
在 meta-qt6/classes/ 目录下创建 populate_sdk_qt6.bbclass 文件。
SUMMARY = "Meta package for building an installable Qt6 toolchain and SDK" inherit populate_sdk populate_sdk_qt6_base TOOLCHAIN_HOST_TASK:append = " nativesdk-packagegroup-qt6-toolchain-host" TOOLCHAIN_TARGET_TASK:append = " packagegroup-qt6-modules" FEATURE_PACKAGES_qtcreator-debug = "packagegroup-qt6-qtcreator-debug"
在 meta-qt6/recipes-qt/packagegroups/ 目录下创建 packagegroup-qt6-qtcreator-debug.bb 文件。
SUMMARY = "Remote debugging tools for QtCreator integration" LICENSE = "MIT" inherit packagegroup # Override by distro if needed VIRTUAL-RUNTIME_qtcreator-debug-ssh-daemon ?= "openssh-sshd" RDEPENDS:${PN} = " \ gdbserver \ ${VIRTUAL-RUNTIME_qtcreator-debug-ssh-daemon} \ openssh-sftp-server \ qtdeclarative \ "
在 meta-toradex-demos/recipes-images/images/ 目录下创建 packagegroup-tdx-qt6.bb 文件。
SUMMARY = "Packagegroup which provides most QT6 libraries and a QT6 demo" PACKAGE_ARCH = "${MACHINE_ARCH}" inherit packagegroup PROVIDES = "${PACKAGES}" PACKAGES += " \ ${PN}-fonts \ ${PN}-libs \ " RRECOMMENDS:${PN} = " \ ${PN}-fonts \ ${PN}-libs \ " SUMMARY:${PN}-fonts = "Some fonts useful for QT5" RRECOMMENDS:${PN}-fonts = " \ ttf-dejavu-common \ ttf-dejavu-sans \ ttf-dejavu-sans-mono \ ttf-dejavu-serif \ " SUMMARY:${PN}-libs = "QT5 libraries" RRECOMMENDS:${PN}-libs = " \ qt3d \ qtbase \ qtcharts \ qtcoap \ qtconnectivity \ qtdatavis3d \ qtdeclarative \ qtimageformats \ qtlottie \ qtmqtt \ qtmultimedia \ qtnetworkauth \ qtopcua \ qtquick3d \ qtquicktimeline \ qtremoteobjects \ qtscxml \ qtsensors \ qtserialbus \ qtserialport \ qtsvg \ qttools \ qttranslations \ qtvirtualkeyboard \ ${@bb.utils.contains('DISTRO_FEATURES', 'wayland', 'qtwayland', '', d)} \ qtwebchannel \ qtwebsockets \ "
在 meta-toradex-demos/recipes-images/images/ 目录下创建 tdx-reference-multimedia-qt6-image.bb 文件。
require tdx-reference-minimal-image.bb SUMMARY = "Toradex Embedded Linux Reference Multimedia Image" DESCRIPTION = "Image for BSP verification with QT and multimedia features" inherit populate_sdk_qt6 #Prefix to the resulting deployable tarball name export IMAGE_BASENAME = "Reference-Multimedia-Image" IMAGE_FEATURES += " \ ${@bb.utils.contains('DISTRO_FEATURES', 'wayland', 'weston', \ bb.utils.contains('DISTRO_FEATURES', 'x11', 'x11-base', '', d), d)} \ " IMAGE_INSTALL += " \ packagegroup-tdx-cli \ packagegroup-tdx-graphical \ packagegroup-tdx-qt6 \ packagegroup-fsl-isp \ \ bash \ coreutils \ less \ makedevs \ mime-support \ net-tools \ util-linux \ v4l-utils \ \ gpicview \ media-files \ "
在 build/conf/bblayers.conf 将 meta-qt6 添加进来,并移除原来的 meta-qt5。
# LAYER_CONF_VERSION is increased each time build/conf/bblayers.conf # changes incompatibly LCONF_VERSION = "7" BBPATH = "${TOPDIR}" BBFILES ?= "" BBLAYERS ?= " \ ${TOPDIR}/../layers/meta-toradex-nxp \ ${TOPDIR}/../layers/meta-freescale \ ${TOPDIR}/../layers/meta-freescale-3rdparty \ \ ${TOPDIR}/../layers/meta-toradex-bsp-common \ \ ${TOPDIR}/../layers/meta-openembedded/meta-oe \ ${TOPDIR}/../layers/meta-openembedded/meta-filesystems \ ${TOPDIR}/../layers/meta-openembedded/meta-gnome \ ${TOPDIR}/../layers/meta-openembedded/meta-xfce \ ${TOPDIR}/../layers/meta-openembedded/meta-networking \ ${TOPDIR}/../layers/meta-openembedded/meta-multimedia \ ${TOPDIR}/../layers/meta-openembedded/meta-python \ ${TOPDIR}/../layers/meta-freescale-distro \ ${TOPDIR}/../layers/meta-toradex-demos \ ${TOPDIR}/../layers/meta-qt5 \ \ \ ${TOPDIR}/../layers/meta-toradex-distro \ ${TOPDIR}/../layers/meta-yocto/meta-poky \ ${TOPDIR}/../layers/openembedded-core/meta \ " #${TOPDIR}/../layers/meta-qt5
build/conf/local.conf 添加下面两个配比,移除 X11 和 directfb 相关配置。
DISTRO_FEATURES:remove = " directfb x11" IMAGE_INSTALL:remove = " gpicview"
最后使用 bitbake 命令即可编译包含 Qt6 的镜像和 SDK。
Verdin AM62 LVGL 移植
基于 NXP iMX8MM 测试 Secure Boot 功能
隆重推出 Aquila - 新一代 Toradex 计算机模块
Verdin iMX8MP 调试串口更改
NXP iMX8MM Cortex-M4 核心 GPT Capture 测试
