新品速递
艾讯宏达最新推出强固型无风扇嵌入式系统GT6020/360
2005/5/25 10:57:00
GT6020/360
Fanless Embedded System with Intel ULV Celeron 400MHz Processor
�Fanless operation
�Supports Intel ULV Celeron 400MHz processor
�Unique mechanical design for thermal solution
�High performance with extremely low power
�Full feature I/O
�Supports PC/104 , CompactFlash
�PCI slot expansion support
�Three LAN port
�One 2.5"/3.5” HDD drive bay
�90watt AC-in power supply
�Desktop or wall mount
Specification
Standard Color:
        White
Construction:
        Aluminum die-casting and heavy-duty steel
System:
        SYS7360V3EA
System Memory:
        184-pin DDR DIMM max. up to 1GB
System I/O Outlet:
        9-pin D-Sub male connector,COM1,3,4 for RS232
        9-pin D-Sub male connector, COM2 for RS485/422/232
        15-pin D-Sub female connector for VGA
        25-pin D-Sub female connector for LPT
        RJ45 connector for 10/100Base-T Ethernent
        USB connector
        Vac 100 -240 power input connector
Extension
        2.5"/3.5" HDD drive bay
        CompactFlash Type II slot
        PC104/PC104 module expansion slot
        PCI slot
System Indicator
        green LED for system power-on
        orange LED for HDD active
Power Supply
        Input rating:Vac 100-240 universal/1Amp,
        Output rating: 100 Watt,
        Output voltage: 5VDC 10A, 12VDC 3A
Environmental
        Operating temperature: 0oC to 50oC
        Storage temperature: -25oC  to 80oC
        Humidity:10-90% RH (no condensation)
        Vibration endurance:2Grms
        w/CF(5-500Hz,X,Y,Z directions) 0.5Grms
        w/HDD(5-500Hz,X,Y,Z directions)
        Certification:CE
        Dimensions:220mmx280mmx90mm (WxDxH)
        EOS Support:XPE, WinCE, Linux
Optional
        Compact Flash:32M,64M,128M,256M,512M
        2.5" HDD:20G,40G
        DDR DIMM:256M,512M
艾讯宏达金典产品选型目录
艾讯宏达i5系列工业平板电脑PAD6315-i54C
艾讯宏达环保专用平板电脑PAD6315-BTHB
艾讯宏达嵌入式无风扇主机助力搬运机器人的发展
艾讯宏达支持双ISA的B85芯片组ATX主板
