新品速递
美国EXACQ公司最新推出 CH-3160高速数采卡
——— 4 Analog Inputs, 40MS/s Speed, 16 Digital I/O
Features:
·4 Analog Input Channels
·Separate 40 MS/s A/D Converter per Channel
·12 Bit A/D Resolution
·16 MB* Local Acquisition Memory
·Analog, Digital, Software Triggering Modes
·1 Hz Sample Clock Resolution from onboard DDS
·16 Digital I/Os, Synchronous with Analog Inputs
·2 Counter/Timers
·PCI Bus-Mastering Transfers at > 80 MB/s sustained
·Multiple board synchronization
·Onboard 143 MHz, 32 Bit DSP for Numerical Coprocessing
·Windows 98/ME/2000/XP, Linux Compatibility
·64 MB Memory Option Now Available
Software Included:
Exacq Control Center?
-a powerful application that provides plug and play simplicity for easy setup, test and configuration of all Exacq boards in the system.
Exacq Bench
-a complete suite of software measurement tools, including oscilloscope, spectrum analyzer, waveform generator, DC voltage generator, logic analyzer, voltmeter, logic analyzer, and strip chart recorder. Full source code to Exacq Bench included.
Third-Party Software Support
-Full support of popular third-party applications is provided, including LabVIEW, MATLAB, DASYLab, TestPoint, VEE Pro, and Microsoft Excel.
Exacq SDK
-a full software development environment for all Exacq hardware, with thoroughly-documented calls and extensive source code samples in C++, Visual Basic and ActiveX.
Exacq DSP Tools
-Every Exacq data acquisition board is designed on a DSP-based architecture. In addition to providing performance and accuracy benefits, DSP functionality is also provided, including FFT, Digital Filtering, FIR Filtering.
The Exacq Technologies CH-3160 High Speed Data Acquisition Board was designed to provide superior high-speed functionality and performance at a low price. The CH-3160 utilizes 16 MB of onboard memory (64 MB memory option now available), a local processor and PCI bus mastering to provide absolute glitch-free capture of analog signals of a length limited only by host RAM or Hard Drive size, even with a non-realtime PC operating system like Windows.
With four inputs and excellent dynamic range, the CH-3160 is ideal for communications applications, such as IQ demodulation. With high-speed 40 MS/s capture, RAM and DSP control, the CH-3160 is ideal for high-speed, lossless, sustained data recording. 12 Bit resolution, high-speed precision and flexible triggering options make the board ideal for all high-speed data acquisition applications.
The onboard DSP coprocessor can offload intensive preprocessing steps, such as FFTs and digital filtering, to free the host program for higher-level algorithms and applications.
Multiple Boards in a System: External clock and triggering features allow multiple CH-Series boards to be synchronized in a system.
The CH-3160 is PCI Plug-and-Play, and digitally calibrated, so there are no jumpers or potentiometers to manually adjust.
MCC CB7210.2芯片资料
MCC PMD系列产品选型指南
