SYNAPTICS TOUCHPAD触控鼠标
——— 特价销售SYNAPTICS 触控板
2007/1/8 15:21:00
SYNAPTICS TOUCHPAD广泛应用于工业控制设备,笔记本电脑,军工设,备智能产品,可完全取代传统轨迹球鼠标.
________________________________________
主要性能参数
PHYSICAL SPECIFICATIONS
Module Dimensions: Size 65.0x49.0 mm
Custom sizing is available
PCB Thickness: Standard PCB thicknesses: 1.09mm
Weight: Weight ranges from 4.0g to 14.7g
Rated Life: >1 million users
ENVIRONMENTAL SPECIFICATIONS
Operating Temperature: 0℃ to 60℃
Operating Humidity: 5%-95% relative humidity, non-condensing
Storage Temperature: -40℃ to 65℃
ESD: 15Kv applied to front surface(when properly mounted)
ELECTRICAL SPECIFICATIONS
Power Supply Voltage: 5.0Volt±10%
Power Supply Current: 3.0ma nominal operating current for PS/2 interface @5.0V
1.5Ma nominal operating current @3.3V
Optional low power modes:
Doze: 60Ma @3.3V
Steep: 30Ma #3.3V
OPERATING SPECIFICATIONS
Interface: PS/2, TTL Serial and USB
Contact your sales rep for avalability of additional interfaces.
X/Y Position Resolution: >1,000 points/inch (40 points/mm)
O/S Support: Microsoft Windows 9x, ME, NT,2000&XP
主要性能参数
Doze: 60Ma @3.3V
Steep: 30Ma #3.3V
触控板TM41BUL200规格书
