ATOP Industrial Switch Hubs EH2005-Fm/Fs (RoHS compliant)
�Four 10/100BaseT(X) (RJ45)
�One fiber port with ST (-Fm model) or SC (-Fs model)
�Broadcast storm protection
�Support IEEE 802.3/ 802.3u/ 802.3x
�10/100M, Full/Half-Duplex, MDI/MDI-X auto-detection
�Redundant dual DC power inputs
�Operating temperature ranges from 0~60�C
�Rugged high-strength plastic case
�DIN-Rail or wall mounting ability
�Alarm out for power and link failure
Specifications
Technology:
Standards: IEEE802.3, 802.3u, 802.3x
Processing Type: Store and Forward
Flow Control: IEEE802.3x flow control, backpressure flow control
Interface:
RJ45 Ports:
10/100BaseT(X) auto negotiation speed,
Full/Half-duplex mode and auto MDI/MDI-X connection
Fiber port:
100BaseFX with Full/Half-duplex mode
SC connector for Single-mode fiber (-Fs model)
ST connector for Multi-mode fiber (-Fm Model)
LED Indicators:
Power, 10/100M, Data
Power Requirement:
Input Voltage: 9~30 VDC, redundant inputs
Input Current (@24V): 0.25A
Connector: Removable dual 3-pin Terminal Block for power input
Reverse Polarity Protection: Present
Mechanical:
Casing: IP40 protection, plastic case
Temperature:
Operation: 0 ~60�C (32~140�F), Storage:-40 ~85�C (-40~185�F)
Humidity:
5%~95% non-condensing
Dimension:
45mm x 91mm x 80mm (W x H x D)
Weight:
160g
Regulatory Approvals:
Safety: UL
EMI: FCC Part 15, class A
Warranty:
3 years
ATOP 四门控制器GW26A-104运用于某大型工厂门禁系统升级
ATOP SE7932八网32串工业级嵌入式计算机
Atop SE7832六网32串工业级嵌入式计算机
ATOP(上尚)六网两串口工业级可编程控制器SE7802
