新品速递
昭营推出最新PC/104主板
昭营推出最新PC/104主板
——— VSX-6151
SoCDM&P SoC CPU Vortex86SX- 300MHz
Real Time Clock with Lithium Battery Backup
CacheL1:16K I-Cache, 16K D-Cache
BusPC/104 standard compliant
BIOSAMI BIOS
System Memory128MB DDR2 onboard
Watchdog Timer 0 & 1 SetsSoftware programmable from 30.5 �sec. To 512 sec. x 2
sets (Watchdog 1 fully compatible with M6117D)
VGATOPRO TP6508IQ Chipset
VGA and Mono/STN/DSTN/TFT Flat Panel interface support
Onboard 1MB VGA Memory, support resolution up to 1024x768, 256 colors
LANIntegrated 10/100Mbps Ethernet
Flash Disk SupportOnboard 2MB SPI Flash Disk
MSTI EmbedDisk Module (16MB and above)
I/O InterfaceEnhanced IDE port (UltraDMA-100/66/33) x1
FDD x1
RS-232 port x3
RS-232/422/485 port x1
USB port (Ver2.0) x2
Parallel port x1
16-bit GPIO port x1
10/100Mbps Ethernet port x1
Connectors2.0mm 44-pin box header for IDE x1
2.0mm 44-pin box header for LCD x1
2.0mm 10pin box header for VGA x1
2.0mm 10pin box header for USB x1
2.0mm 26-pin box header for Printer x1
2.0mm 20-pin box header for 16-bit GPIO x1
2.0mm 10-pin box header for RS-232 x4
2.0mm 8-pin header for Ethernet x1
2.5mm 5-pin box header for Keyboard x1
2.5mm 5-pin box header for Mouse x1
2.54mm 34-pin box header for FDD x1
2.54mm 4-pin header for -5V, -12V 12V,GND , DC-in x1
2.54mm 3-pin header for RS-485 x1
2.54mm 2-pin header for Reset x1
1.25mm 6-pin header for JTAG x1
Power RequirementSingle Voltage 5V @ 620mA
Weight100g
Board Size90 X 96mm (3.54 x 3.77 inches)
Operating Temperature-20�C ~ 70�C
-40�C ~ 85�C(Optional)
WinCE的软件调试
昭营 eBOX-2310MX-D4C 工业级嵌入式微型计算机
昭营 eBOX-2310MX-JSK 工业级嵌入式微型计算机
昭营 eBOX-2350MX-AP 坚固型导轨式无风扇嵌入式系统
eBOX 2310MX-C85AP 坚固型导轨式无风扇嵌入式系统
