新品速递
ICOP 昭营最新PC/104 VDX-6354
2008/11/26 12:00:00
Specifications:
SoCDM&P SoC CPU Vortex86DX- 800MHz
Real Time Clock with Lithium Battery Backup
CacheL1:16K I-Cache, 16K D-Cache, L2 Cache 128KB
BusPC/104 standard compliant
PC-104, PC/104 (Optional)
BIOSAMI BIOS
System Memory256MB DDR2 Onboard
Watchdog Timer 0 & 1 SetsSoftware programmable from 30.5 �sec. To 512 sec. x 2
sets (Watchdog 1 fully compatible with M6117D)
VGAXGI Volari Z9s Chipset
VGA and TFT Flat Panel Interface Support
Onboard 32MB VGA Memory, support resolution up to
1280 x 1024, 16M colors
LANIntegrated 10/100Mbps Ethernet
AudioCM119 USB Audio controller
Flash Disk SupportOnboard 4MB SPI Flash Disk
MSTI EmbedDisk Module (16MB and above)
I/O InterfaceEnhanced IDE port (UltraDMA-100/66/33) x1
RS-232 port x3
RS-232/422/485 port x1
USB port (Ver2.0) x2
Parallel port x1
16-bit GPIO port x1
10/100Mbps Ethernet port x1
Connectors2.0mm 44-pin box header for IDE x1
2.0mm 44-pin box header for LCD x1
2.0mm 10-pin box header for VGA x1
2.0mm 10-pin box header for USB x1
2.0mm 26-pin box header for Printer x1
2.0mm 20-pin box header for 16-bit GPIO x1
2.0mm 10-pin box header for RS-232 x4
2.0mm 8-pin header for Ethernet x1
2.54mm 5-pin box header for Keyboard x1
2.54mm 5-pin box header for Mouse x1
2.54mm 4-pin header for -5V, -12V, 12V, GND, DC-in x1
2.54mm 3-pin header for RS-485 x1
2.54mm 2-pin header for Reset x1
2.54mm 7-pin header for Redundancy Signal x1(Optional)
2.54mm 2-pin header for System-Fail-SW x1(Optional)
1.25mm 6-pin wafer for JTAG x1
1.25mm 4-pin wafer for Line-out/MIC-in x2
Power RequirementSingle Voltage 5V @ 740mA
Weight90g
Board Size90 X 96mm (3.54 x 3.77 inches)
Operating Temperature-20�C ~ 70�C
-40�C ~ 85�C(Optional)
WinCE的软件调试
昭营 eBOX-2310MX-D4C 工业级嵌入式微型计算机
昭营 eBOX-2310MX-JSK 工业级嵌入式微型计算机
昭营 eBOX-2350MX-AP 坚固型导轨式无风扇嵌入式系统
eBOX 2310MX-C85AP 坚固型导轨式无风扇嵌入式系统
