品富推出 APC-3931 嵌入式平板电脑
2009/11/23 9:20:00
Features:
*Fanless Design
*Default Intel Celeron M 1.5GHz up to Pentium M 1.8GHz CPU
*19"High Brightness (300cd/m) TFT LCD with resolution of 1280*1024
*Optional GFG Resistive screen
*Optional optical bonding for Sunlight readable solution
*Aluminum (10mm) bezel and Stainless steel housing (Anti-Corrosion Coating)
*Support 1*SO-DIMM up to 1GB DDR SDRAM
*Support 1*CD-ROM on the back side (optional)
*Support 1*2.5 HDD space
*AC universal power input,optional DC 11~32V power input
Specifications: |
System Specifications | |
CPU | Default Intel Socket 478 Celeron M 1.5GHz up to Pentium M 1.8GHz |
DRAM | 1 x SO-DIMM socket, support DDR 200/266/333 up to 1GB SDRAM |
Storage | Supports 1 x 2.5" HDD, 1 x CD-ROM on the back side (optional) |
I/O Ports | 2 x COM port , 4 x USB 2.0, 1 x RJ-45 port (10/100 Mbps), 1xAudio Line-in, Line-out, Mic, 1 x PS/2 keyboard & mouse, 1 x VGA, 1x power switch |
Expansion | No Expansion slot |
Fanless / Fan | Fanless |
Touch screen | Resistive (optional) |
Display Specifications | |
LCD | 19" SXGA |
Resolution | 1280x1024 |
Luminance | 300 cd/m |
Backlight Lifetime | 50,000hrs |
Dimension | 483(Dimension W)x440(H)x95(D)mm |
Mechanical Specifications | |
Construction | Sliver / Aluminum (10mm) bezel and stainless steel housing (Anti-Corrosion Coating) |
Power input | AC power 120W, optional DC 11~32V |
Operating Temperature | 0~50 C |
Storage Temperatur | -20~60 C |
Storage Humidity | 10 to 90% @ 40 C, non-condensing |
Vibration | 1G / 5~500Hz (Random) |
Shock | 15G peak acceleration (11 msec. duration) |
Drop | 92cm (1 Corner, 3 Edge, 6 Surface) |
Certificate | Meet CE / FCC Class A, IEC 60945 |
Mounting | 19" rack / VESA 75 mount |
Weight (net) | 18kgs |
APLEX北京迁址通知
品富2010年人机界面产品列表
品富(APLEX)ACOM-945 COM板
品富(APLEX)PB-700S MINI 载板
品富(APLEX)PB-700F MINI载板
