softing公司在不断探索下,研发出了性能更可靠、更稳定的TestCUBE2硬件,
这是一款可配置ECU诊断仿真的工具,具备真实总线通讯能力,
可以用来仿真ECU诊断功能的可配置软硬件解决方案。
您可以仅仅使用这台设备,就可以同时仿真多个ECU甚至整个车辆环境。
TestCUBE2的应用领域包括:开发、测试、生产阶段的测试设备;
诊断仪或产品系统的释放测试;诊断仪的回归测试。
TestCUBE2的优势在于:
1)首先其在ECU开发完成之前进行测试;
2)可以大量仿真文件的归档管理;
3)快速熟悉和易于使用;
4)通过编程接口修改和交换仿真行为;
5)由高可配置性带来的高测试质量;
6)错误环境测试;
7)提供诊断协议模板;
8)可以脱离PC独立运行;
9)支持模拟输入输出;
10)支持导入DBC文件进行残余总线仿真。
TestCUBE2 – frontloading in test preperation
链接:http://automotive.softing.com/cn/products.html
Creating test sequences is often challenging along the entire value chain: The ECU required as a test counterpart is missing. But particularly in the test environment, the test methodology should be developed at an early stage to run function tests as soon as the ECUs are available. Which means it is useful if the test sequences are already available and tested.
This is simple with TestCUBE2 because test sequences can already be verified during ECU development.
The ECU simulation TestCUBE2 is the counterpart for all cases of application in which an ECU is not yet (e.g. preparation of workshop tests) or no longer (e.g. tester regression test) available.
