雷勃无锡人才集结令
Yes, YOU~~~!!!
WE WANT YOU!
雷勃无锡最新人才集结令,感兴趣者请联系HR Ms Yuan
yujia.yuan@regalbeloit.com
Tel: 86 510 81831760
高压电机设计工程师II
职位描述:
1.Advanced and experienced knowledge inabove NEMA motor ,meet customer special requirement,convertcustomer spec to design detail spec,independentcomplete product design.在超过NEMA 范围的大电机有领先的知识满足客户的特殊需求,给客户提供解决方案,获取客户和开发产品规格的要求。将客户需求转换为产品需求,独立完成满足客户的产品
2.Creat test plan and validation productreliability and failed risk 创建测试计划来验证产品或组件,基本了解的可靠性和失效机制
3.Support production, sourcing and qualityteam develop new product. Optimize parts cost and quality, solve the techniqueproblem.支持生产、采购和质量在新产品实施过程中的问题,设计开发和生产新产品来支持优化的可制造性,质量和成本,分析实验数据优化设计
4.Design motor part and component (endframe, shaft, main frame, terminal box, fan guard and etc. analysis andcalculate product performance, optimize project. analysis test result and optimize design forward.设计产品的零、部件(端盖,轴,机座,接线座,风罩等等),并进行分析计算,优化方案实施
5.Verify the BOM , response for drawingaccuracy, maintenance technique database and parts construction,校对BOM表设计的准确性,对CAD绘图的准确性负责, 汇总和维护零部件结构 ,做好标准化工作,编制设计指导,设计原则和实施改进
6.Familiar with global product standard,make sure the product meet the standard, make up design guidance,design principal and improvement plan. 熟悉电机标准,确保设计符合各类标准
7.Design difficult product,make sure the product have reliable process and reliable qualitycontrol. And control product cost.设计有难度的产品,确保产品的工艺性和质量,成本得到保证
8.Train design engineer get new design idea and new product standardidea used in ordinary work.培养设计工程师有先进设计和标准化设计的理念,并在工作中得以应用.
教育背景:
Bachelor's degree on electrical&mechanical or equivalent related experience;机械设计电气化专业相关专业,学士学位以上
工作经验:
1、Skilled insoftware including motor design software; 感应电机设计方面有充足的经验,
2、5 + years motordesign experience 五年电机设计经验及以上;
3.Skilled with AUTO CAD and SolidWorks 熟悉办公软件包括电机设计软件。
其它:
1.Precedence Familial with Oracle/SPA/PLMsystem application熟悉ORACLE/SPA/PLM系统运行
2.Familial with IEC/NEMA high efficiencymotor design, familial with VSD motor design, familial with motor internationalstandard熟悉NEMA/IEC 高效电机的设计,熟悉变频电机的设计,熟悉感应电机行业标准
3.Green Belt in Lean Six Sigmapreferred 绿带者经验者优先
4.Fluent English .英语流利。
高压电机设计工程师III
职位描述:
1.Understand customer spec and makecomponent design through finished assembly to meet it。吃透客户的需求从零部件设计到整个产品装配来满足客户要求.
2.Design and improve products consideringcost, quality, and manufacturability with a thorough understanding of designtools and methods考虑成本,质量和制造工艺的基础上设计和提高产品
3.Support manufacture, purchase,quality solve problem,improve feasibility in design and manufacture process ,put forward quality control plan, controldesign cost,analysis test data and optimize支持生产、采购和质量在新产品实施过程中的问题,设计开发和生产新产品来支持优化的可制造性,控制成本 ,分析实验数据优化设计
4.Support application engineer to get theorder 支持应用工程师得到订单
5.Excute projects to reduce cost and improve quality 做降本和提高质量的项目
6.Collaborate with other engineers and manufacturing team to develop producible,cost effective and reliable products to launch into the HV market.和其他工程师通力合作,协作制造团队来发展工艺性好,成本划算和可靠的产品来释放到高压市场
7.Understand the motor standard,make sure the product meet standard request 熟悉电机标准,确保设计符合各类标准
8.Cultivate other engineer to improve theskill 培养其他工程师来提高技能
教育背景:
工作经验:1.At least 3 years’ foreign companywork experience; 至少3年以上外资企业工作经验
2、10 + years’experience on bigger induction motor LV &HV. 10年以上中型高低压工业电机设计工作经验(H710以上高压电机和绕线电机设计)
3.With experience for team building andlead ship有丰富的团队领导和沟通能力。
其它:
1.Experience in motor design &manufacturing of rotating electric machines在电机设计制造方面有经验。
2.Knowledge of ERP tool, preferably Oracle11i 对于ERP 有一定的知识,如果对于Oracle 11i有了解更佳。
3.LeanSix Sigma Trained 六西格玛
卓越运营助理
职位描述
1、 负责月度5S评分,指导5S改善及标准建立,5S标识的维护工作;
2、 负责合理化建议的收集,以及状态的跟踪,积分的统计及礼品的发放;
3、 JIB稽核安排工作;
4、 Yellow Belt(黄带)相关模块培训工作;
5、 HET相关工作的推广及维护;
6、 参与各类改善活动,跨部门支持工作;
7、 服从内部工作的安排。
职位要求:
1.1年以上工作经验;
2.对机制造流程熟悉。
电机装配过程及成品检验
职位描述
1.负责供应商电机制造过程的质量控制及成品进货检验;
2.按标准、图纸、检验规范等技术文件进行检验并做好检验记录,对检验结果及记录的正确性负责;
3.按不合格品控制程序要求对不合格品及时开具不合格品跟踪单、信息反馈单、确认报废的开具废品通知单,对单子填写正确性以及传递的及时性负责;
4.负责所在岗位图纸、量具管理及日常5S工作。
职位要求:
1.大专以上文化,3年以上电机行业工作经验;
2.识图,能够熟练使用游标卡尺、外径千分尺等通用量具;
3.了解机械制造基本知识,了解形位公差的概念(同心度、圆度、跳动、位置度、平行度、平面度);
4.无色盲色弱。
优先条件:
了解SPC、CPK、Guage RR。
深耕六十载,携手创未来
马拉松电机正式发布SCA系列IE2能效低压产品
学以致用、助力工作--雷勃无锡第一期英语角报导
雷勃电气(无锡)有限公司获CQC授予A类企业资质
财神驾临雷勃,员工齐贺新春 --雷勃无锡迎新春活动报道
