【鑫精诚传感器】压力传感器XJC-S03
特点 Feature
◆压力传感器XJC-S03采用高精度电阻应变式原理
◆可满足 49N-490N范围内的力测量。
◆不锈钢材料,密封焊接,防油、防水、耐腐蚀。
◆S型结构设计,压式承载,安装使用方便灵活。
◆高精度,高稳定性。
◆铝合金/不锈钢材料
◆体积小巧,外型美观
◆动态响应频率高
◆XJC-S03 high-precision resistance strain principle
◆ Can meet force measurement in the range of 49N-490N.
◆ Stainless steel, sealed welding, oil, water, corrosion resistance
◆ Running structural design, pressure-bearing, easy to install and flexible.
◆Intrinsically safe products for harsh environments and dangerous situations.
◆ Aluminum / stainless steel
◆ Small size, appearance
◆ Dynamic response of high frequency
技术参数(Technical parameters):
量程 Capacity | 0-(49N-490N) (5KG-50KG) | 材质 Material
| 铝合金Aluminum alloy 不锈钢Stainless steel | |
精度 Accuracy | 0.03% F.S. | 输出灵敏度 Rated output | 2.0mV/V |
使用电压力 Recommended excitation | 5-10VDC | 最大使用电压 Maximum excitation | 15V | |
固有频率 Natural frequency | ≥2KHZ | 温度补偿范围 Compensated temp range | - 10 ~ 60 ºC | |
滞后 Hysteresis | 0.03% F.S. | 工作温度 范围 Operating temp range | - 20 ~ 80 ºC | |
重复性 Repeatability
| 0.03% F.S. | 绝缘电阻 Insulation
| ≥5000MΩ/100VDC | |
输入阻抗 Input impedance | 350± 5 Ω | 输出阻抗 Output impedance | 350± 5 Ω | |
蠕变 (30分钟) Creep (30min) | 0.01% F.S. | 温度灵敏度漂移 Temp effect on output | 0.05% F.S. / 10ºC | |
零点输出 Zero balance | ± 2% F.S. | 零点温度漂移 Temp effect on zero | 0.05% F.S. / 10ºC | |
安全超载 Safe load limit | 150% | 极限超载 Ultimate load limit | 200% | |
电缆线尺寸 Cable size | ∅3 x3m | 使用寿命 Life | 满量程100万次以上 Full scale more than 1 million times | |
电缆线连接方式 Wire Connection | Ex + : 红 Red; Ex - : 黑 Black; Sig + : 绿 Green; Sig - : 白 White |
主要应用 Applications
小力值试验机、料斗秤、 插拔力测试仪,铆钉机,焊接机,冷热压贴膜机,键盘按钮手感度测试仪等拉压力测试仪器以及自动化设备领域和测试领域。
Mainly applied in tension and compression testing instruments and automatic equipments fields, such as small range of force testing instruments, hopper scales, i n s e r t i o n force test instruments, riveting machine, welding machine, hot & cold lamination machine, feeling tester for keyboard switch, and etc.
*外形和量程可根据客户的要求特殊定制 / Dimension and capacity can be customized by request.
鑫精诚传感器 诚邀您参观:IBTE 2020深圳电池技术展
展会进行时|鑫精诚传感器参展2020华南工博会,已在线等待!
邀请函|鑫精诚传感器欢迎您莅临上海DIC EXPO 2020展会
测力传感器的应用范围及使用环境
多维力传感器被广泛应用
