业界动态
G2D图像处理硬件调用和测试-基于米尔-全志T113-i开发板
MYC-YT113i核心板及开发板
真正的国产核心板,100%国产物料认证
国产T113-i处理器配备2*Cortex-A7@1.2GHz ,RISC-V
外置DDR3接口、支持视频编解码器、HiFi4 DSP
接口丰富:视频采集接口、显示器接口、USB2.0 接口、CAN 接口、千兆以太网接口
工业级:-40℃~+85℃、尺寸37mm*39mm
邮票孔+LGA,140+50PIN
全志 T113-i 2D图形加速硬件支持情况
Supports layer size up to 2048 x 2048 pixels
Supports pre-multiply alpha image data
Supports color key
Supports two pipes Porter-Duff alpha blending
Supports multiple video formats 4:2:0, 4:2:2, 4:1:1 and multiple pixel formats (8/16/24/32 bits graphics
layer)
Supports memory scan order option
Supports any format convert function
Supports 1/16× to 32× resize ratio
Supports 32-phase 8-tap horizontal anti-alias filter and 32-phase 4-tap vertical anti-alias filter
Supports window clip
Supports FillRectangle, BitBlit, StretchBlit and MaskBlit
Supports horizontal and vertical flip, clockwise 0/90/180/270 degree rotate for normal buffer
Supports horizontal flip, clockwise 0/90/270 degree rotate for LBC buffer
可以看到 g2d 硬件支持相当多的2D图像处理,包括颜色空间转换,分辨率缩放,图层叠加,旋转等
开发环境配置
基础开发环境搭建参考上上上一篇
https://bbs.elecfans.com/jishu_2408808_1_1.html
除了工具链外,我们使用 opencv-mobile 加载输入图片和保存结果,用来查看颜色转换是否正常
g2d硬件直接采用标准的 Linux ioctl 操纵,只需要引入相关结构体定义即可,无需链接so
https://github.com/MYIR-ALLWINNER/framework/blob/develop-yt113-framework/auto/sdk_lib/include/g2d_driver.h
此外,g2d的输入和输出数据必须在dmaion buffer上,因此还需要dmaion.h头文件,用来分配和释放dmaion buffer
https://github.com/MYIR-ALLWINNER/framework/blob/develop-yt113-framework/auto/sdk_lib/include/DmaIon.h
基于C语言实现的YUV转RGB
这里复用之前T113-i JPG解码的函数
void yuv420sp2rgb(const unsigned char* yuv420sp, int w, int h, unsigned char* rgb)
    const unsigned char* yptr = yuv420sp;
    const unsigned char* vuptr = yuv420sp + w * h;
    for (int y = 0; y < h; y += 2)
        const unsigned char* yptr0 = yptr;
        const unsigned char* yptr1 = yptr + w;
        unsigned char* rgb0 = rgb;
        unsigned char* rgb1 = rgb + w * 3;
        int remain = w;
#define SATURATE_CAST_UCHAR(X) (unsigned char)::std::min(::std::max((int)(X), 0), 255);
        for (; remain > 0; remain -= 2)
            // R = 1.164 * yy + 1.596 * vv
            // G = 1.164 * yy - 0.813 * vv - 0.391 * uu
            // B = 1.164 * yy              + 2.018 * uu
            // R = Y + (1.370705 * (V-128))
            // G = Y - (0.698001 * (V-128)) - (0.337633 * (U-128))
            // B = Y + (1.732446 * (U-128))
            // R = ((Y << 6) + 87.72512 * (V-128)) >> 6
            // G = ((Y << 6) - 44.672064 * (V-128) - 21.608512 * (U-128)) >> 6
            // B = ((Y << 6) + 110.876544 * (U-128)) >> 6
            // R = ((Y << 6) + 90 * (V-128)) >> 6
            // G = ((Y << 6) - 46 * (V-128) - 22 * (U-128)) >> 6
            // B = ((Y << 6) + 113 * (U-128)) >> 6
            // R = (yy + 90 * vv) >> 6
            // G = (yy - 46 * vv - 22 * uu) >> 6
            // B = (yy + 113 * uu) >> 6
            int v = vuptr[0] - 128;
            int u = vuptr[1] - 128;
            int ruv = 90 * v;
            int guv = -46 * v + -22 * u;
            int buv = 113 * u;
            int y00 = yptr0[0] << 6;
            rgb0[0] = SATURATE_CAST_UCHAR((y00 + ruv) >> 6);
            rgb0[1] = SATURATE_CAST_UCHAR((y00 + guv) >> 6);
            rgb0[2] = SATURATE_CAST_UCHAR((y00 + buv) >> 6);
            int y01 = yptr0[1] << 6;
            rgb0[3] = SATURATE_CAST_UCHAR((y01 + ruv) >> 6);
            rgb0[4] = SATURATE_CAST_UCHAR((y01 + guv) >> 6);
            rgb0[5] = SATURATE_CAST_UCHAR((y01 + buv) >> 6);
            int y10 = yptr1[0] << 6;
            rgb1[0] = SATURATE_CAST_UCHAR((y10 + ruv) >> 6);
            rgb1[1] = SATURATE_CAST_UCHAR((y10 + guv) >> 6);
            rgb1[2] = SATURATE_CAST_UCHAR((y10 + buv) >> 6);
            int y11 = yptr1[1] << 6;
            rgb1[3] = SATURATE_CAST_UCHAR((y11 + ruv) >> 6);
            rgb1[4] = SATURATE_CAST_UCHAR((y11 + guv) >> 6);
            rgb1[5] = SATURATE_CAST_UCHAR((y11 + buv) >> 6);
            yptr0 += 2;
            yptr1 += 2;
            vuptr += 2;
            rgb0 += 6;
            rgb1 += 6;
#undef SATURATE_CAST_UCHAR
        yptr += 2 * w;
        rgb += 2 * 3 * w;
基于ARM neon指令集优化的YUV转RGB
考虑到armv7编译器的自动neon优化能力较差,这里针对性的编写 arm neon inline assembly 实现YUV2RGB内核部分,达到最优化的性能,榨干cpu性能
void yuv420sp2rgb_neon(const unsigned char* yuv420sp, int w, int h, unsigned char* rgb)
#if __ARM_NEON
    uint8x8_t _v128 = vdup_n_u8(128);
    int8x8_t _v90 = vdup_n_s8(90);
    int8x8_t _v46 = vdup_n_s8(46);
    int8x8_t _v22 = vdup_n_s8(22);
    int8x8_t _v113 = vdup_n_s8(113);
#endif // __ARM_NEON
#if __ARM_NEON
        int nn = w >> 3;
        int remain = w - (nn << 3);
#else
        int remain = w;
#if __ARM_NEON
#if __aarch64__
        for (; nn > 0; nn--)
            int16x8_t _yy0 = vreinterpretq_s16_u16(vshll_n_u8(vld1_u8(yptr0), 6));
            int16x8_t _yy1 = vreinterpretq_s16_u16(vshll_n_u8(vld1_u8(yptr1), 6));
            int8x8_t _vvuu = vreinterpret_s8_u8(vsub_u8(vld1_u8(vuptr), _v128));
            int8x8x2_t _vvvvuuuu = vtrn_s8(_vvuu, _vvuu);
            int8x8_t _vv = _vvvvuuuu.val[0];
            int8x8_t _uu = _vvvvuuuu.val[1];
            int16x8_t _r0 = vmlal_s8(_yy0, _vv, _v90);
            int16x8_t _g0 = vmlsl_s8(_yy0, _vv, _v46);
            _g0 = vmlsl_s8(_g0, _uu, _v22);
            int16x8_t _b0 = vmlal_s8(_yy0, _uu, _v113);
            int16x8_t _r1 = vmlal_s8(_yy1, _vv, _v90);
            int16x8_t _g1 = vmlsl_s8(_yy1, _vv, _v46);
            _g1 = vmlsl_s8(_g1, _uu, _v22);
            int16x8_t _b1 = vmlal_s8(_yy1, _uu, _v113);
            uint8x8x3_t _rgb0;
            _rgb0.val[0] = vqshrun_n_s16(_r0, 6);
            _rgb0.val[1] = vqshrun_n_s16(_g0, 6);
            _rgb0.val[2] = vqshrun_n_s16(_b0, 6);
            uint8x8x3_t _rgb1;
            _rgb1.val[0] = vqshrun_n_s16(_r1, 6);
            _rgb1.val[1] = vqshrun_n_s16(_g1, 6);
            _rgb1.val[2] = vqshrun_n_s16(_b1, 6);
            vst3_u8(rgb0, _rgb0);
            vst3_u8(rgb1, _rgb1);
            yptr0 += 8;
            yptr1 += 8;
            vuptr += 8;
            rgb0 += 24;
            rgb1 += 24;
#else
        if (nn > 0)
            asm volatile(
                "0:                             \n"
                "pld        [%3, #128]          \n"
                "vld1.u8    {d2}, [%3]!         \n"
                "vsub.s8    d2, d2, %12         \n"
                "pld        [%1, #128]          \n"
                "vld1.u8    {d0}, [%1]!         \n"
                "pld        [%2, #128]          \n"
                "vld1.u8    {d1}, [%2]!         \n"
                "vshll.u8   q2, d0, #6          \n"
                "vorr       d3, d2, d2          \n"
                "vshll.u8   q3, d1, #6          \n"
                "vorr       q9, q2, q2          \n"
                "vtrn.s8    d2, d3              \n"
                "vorr       q11, q3, q3         \n"
                "vmlsl.s8   q9, d2, %14         \n"
                "vorr       q8, q2, q2          \n"
                "vmlsl.s8   q11, d2, %14        \n"
                "vorr       q10, q3, q3         \n"
                "vmlal.s8   q8, d2, %13         \n"
                "vmlal.s8   q2, d3, %16         \n"
                "vmlal.s8   q10, d2, %13        \n"
                "vmlsl.s8   q9, d3, %15         \n"
                "vmlal.s8   q3, d3, %16         \n"
                "vmlsl.s8   q11, d3, %15        \n"
                "vqshrun.s16 d24, q8, #6        \n"
                "vqshrun.s16 d26, q2, #6        \n"
                "vqshrun.s16 d4, q10, #6        \n"
                "vqshrun.s16 d25, q9, #6        \n"
                "vqshrun.s16 d6, q3, #6         \n"
                "vqshrun.s16 d5, q11, #6        \n"
                "subs       %0, #1              \n"
                "vst3.u8    {d24-d26}, [%4]!    \n"
                "vst3.u8    {d4-d6}, [%5]!      \n"
                "bne        0b                  \n"
                : "=r"(nn),    // %0
                "=r"(yptr0), // %1
                "=r"(yptr1), // %2
                "=r"(vuptr), // %3
                "=r"(rgb0),  // %4
                "=r"(rgb1)   // %5
                : "0"(nn),
                "1"(yptr0),
                "2"(yptr1),
                "3"(vuptr),
                "4"(rgb0),
                "5"(rgb1),
                "w"(_v128), // %12
                "w"(_v90),  // %13
                "w"(_v46),  // %14
                "w"(_v22),  // %15
                "w"(_v113)  // %16
                : "cc", "memory", "q0", "q1", "q2", "q3", "q8", "q9", "q10", "q11", "q12", "d26");
#endif // __aarch64__
            int ruv = 90 * v;
            int buv = 113 * u;
            yptr0 += 2;
            yptr1 += 2;
            vuptr += 2;
            rgb0 += 6;
            rgb1 += 6;
        yptr += 2 * w;
        rgb += 2 * 3 * w;
基于G2D图形硬件的YUV转RGB
我们先实现 dmaion buffer 管理器,参考
https://github.com/MYIR-ALLWINNER/framework/blob/develop-yt113-framework/auto/sdk_lib/sdk_memory/DmaIon.cpp
这里贴的代码省略了异常错误处理的逻辑,有个坑是 linux-4.9 和 linux-5.4 用法不一样,米尔电子的这个T113-i系统是linux-5.4,所以不兼容4.9内核的ioctl用法习惯
struct ion_memory
    size_t size;
    int fd;
    void* virt_addr;
    unsigned int phy_addr;
class ion_allocator
public:
    ion_allocator();
    ~ion_allocator();
    int open();
    void close();
    int alloc(size_t size, struct ion_memory* mem);
    int free(struct ion_memory* mem);
    int flush(struct ion_memory* mem);
public:
    int ion_fd;
    int cedar_fd;
ion_allocator::ion_allocator()
    ion_fd = -1;
    cedar_fd = -1;
ion_allocator::~ion_allocator()
    close();
int ion_allocator::open()
    close();
    ion_fd = ::open("/dev/ion", O_RDWR);
    cedar_fd = ::open("/dev/cedar_dev", O_RDONLY);
    ioctl(cedar_fd, IOCTL_ENGINE_REQ, 0);
    return 0;
void ion_allocator::close()
    if (cedar_fd != -1)
        ioctl(cedar_fd, IOCTL_ENGINE_REL, 0);
        ::close(cedar_fd);
        cedar_fd = -1;
    if (ion_fd != -1)
        ::close(ion_fd);
        ion_fd = -1;
int ion_allocator::alloc(size_t size, struct ion_memory* mem)
    struct aw_ion_new_alloc_data alloc_data;
    alloc_data.len = size;
    alloc_data.heap_id_mask = AW_ION_SYSTEM_HEAP_MASK;
    alloc_data.flags = AW_ION_CACHED_FLAG | AW_ION_CACHED_NEEDS_SYNC_FLAG;
    alloc_data.fd = 0;
    alloc_data.unused = 0;
    ioctl(ion_fd, AW_ION_IOC_NEW_ALLOC, &alloc_data);
    void* virt_addr = mmap(NULL, size, PROT_READ|PROT_WRITE, MAP_SHARED, alloc_data.fd, 0);
    struct aw_user_iommu_param iommu_param;
    iommu_param.fd = alloc_data.fd;
    iommu_param.iommu_addr = 0;
    ioctl(cedar_fd, IOCTL_GET_IOMMU_ADDR, &iommu_param);
    mem->size = size;
    mem->fd = alloc_data.fd;
    mem->virt_addr = virt_addr;
    mem->phy_addr = iommu_param.iommu_addr;
    return 0;
int ion_allocator::free(struct ion_memory* mem)
    if (mem->fd == -1)
        return 0;
    iommu_param.fd = mem->fd;
    ioctl(cedar_fd, IOCTL_FREE_IOMMU_ADDR, &iommu_param);
    munmap(mem->virt_addr, mem->size);
    ::close(mem->fd);
    mem->size = 0;
    mem->fd = -1;
    mem->virt_addr = 0;
    mem->phy_addr = 0;
    return 0;
int ion_allocator::flush(struct ion_memory* mem)
    struct dma_buf_sync sync;
    sync.flags = DMA_BUF_SYNC_END | DMA_BUF_SYNC_RW;
    ioctl(mem->fd, DMA_BUF_IOCTL_SYNC, &sync);
    return 0;
然后再实现 G2D图形硬件 YUV转RGB 的转换器
提前分配好YUV和RGB的dmaion buffer
将YUV数据拷贝到dmaion buffer,flush cache完成同步
配置转换参数,ioctl调用G2D_CMD_BITBLT_H完成转换
flush cache完成同步,从dmaion buffer拷贝出RGB数据
释放dmaion buffer
// 步骤1
ion_allocator ion;
ion.open();
struct ion_memory yuv_ion;
ion.alloc(rgb_size, &rgb_ion);
struct ion_memory rgb_ion;
ion.alloc(yuv_size, &yuv_ion);
int g2d_fd = ::open("/dev/g2d", O_RDWR);
// 步骤2
memcpy((unsigned char*)yuv_ion.virt_addr, yuv420sp, yuv_size);
ion.flush(&yuv_ion);
// 步骤3
g2d_blt_h blit;
memset(&blit, 0, sizeof(blit));
blit.flag_h = G2D_BLT_NONE_H;
blit.src_image_h.format = G2D_FORMAT_YUV420UVC_V1U1V0U0;
blit.src_image_h.width = width;
blit.src_image_h.height = height;
blit.src_image_h.align[0] = 0;
blit.src_image_h.align[1] = 0;
blit.src_image_h.clip_rect.x = 0;
blit.src_image_h.clip_rect.y = 0;
blit.src_image_h.clip_rect.w = width;
blit.src_image_h.clip_rect.h = height;
blit.src_image_h.gamut = G2D_BT601;
blit.src_image_h.bpremul = 0;
blit.src_image_h.mode = G2D_PIXEL_ALPHA;
blit.src_image_h.use_phy_addr = 0;
blit.src_image_h.fd = yuv_ion.fd;
blit.dst_image_h.format = G2D_FORMAT_RGB888;
blit.dst_image_h.width = width;
blit.dst_image_h.height = height;
blit.dst_image_h.align[0] = 0;
blit.dst_image_h.clip_rect.x = 0;
blit.dst_image_h.clip_rect.y = 0;
blit.dst_image_h.clip_rect.w = width;
blit.dst_image_h.clip_rect.h = height;
blit.dst_image_h.gamut = G2D_BT601;
blit.dst_image_h.bpremul = 0;
blit.dst_image_h.mode = G2D_PIXEL_ALPHA;
blit.dst_image_h.use_phy_addr = 0;
blit.dst_image_h.fd = rgb_ion.fd;
ioctl(g2d_fd, G2D_CMD_BITBLT_H, &blit);
// 步骤4
ion.flush(&rgb_ion);
memcpy(rgb, (const unsigned char*)rgb_ion.virt_addr, rgb_size);
// 步骤5
ion.free(&rgb_ion);
ion.free(&yuv_ion);
ion.close();
::close(g2d_fd);
G2D图像硬件YUV转RGB测试
考虑到dmaion buffer分配和释放都比较耗时,我们提前做好,循环调用步骤3的G2D转换,统计耗时,并在top工具中查看CPU占用率
sh-4.4# LD_LIBRARY_PATH=. ./g2dtest
INFO   : cedarc: register mjpeg decoder success!
this device is not whitelisted for jpeg decoder cvi
this device is not whitelisted for jpeg encoder rkmpp
INFO   : cedarc: Set log level to 5 from /vendor/etc/cedarc.conf
ERROR  : cedarc: now cedarc log level:5
yuv420sp2rgb 46.61
yuv420sp2rgb 42.04
yuv420sp2rgb 41.32
yuv420sp2rgb 42.06
yuv420sp2rgb 41.69
yuv420sp2rgb 42.05
yuv420sp2rgb 41.29
yuv420sp2rgb 41.30
yuv420sp2rgb 42.14
yuv420sp2rgb 41.33
yuv420sp2rgb_neon 10.57
yuv420sp2rgb_neon 7.21
yuv420sp2rgb_neon 6.77
yuv420sp2rgb_neon 8.31
yuv420sp2rgb_neon 7.60
yuv420sp2rgb_neon 6.80
yuv420sp2rgb_neon 7.01
yuv420sp2rgb_neon 7.11
yuv420sp2rgb_neon 7.06
yuv420sp2rgb_g2d 4.32
yuv420sp2rgb_g2d 4.69
yuv420sp2rgb_g2d 4.56
yuv420sp2rgb_g2d 4.57
yuv420sp2rgb_g2d 4.52
yuv420sp2rgb_g2d 4.54
yuv420sp2rgb_g2d 4.58
yuv420sp2rgb_g2d 4.60
yuv420sp2rgb_g2d 4.67
可以看到 ARM neon 的优化效果非常明显,而使用G2D图形硬件能获得进一步加速,并且能显著降低CPU占用率!
转换结果对比和分析
C和neon的转换结果完全一致,但是g2d转换后的图片有明显的色差
G2D图形硬件只支持 G2D_BT601,G2D_BT709,G2D_BT2020 3种YUV系数,而JPG所使用的YUV系数是改版BT601,因此产生了色差
https://github.com/MYIR-ALLWINNER/myir-t1-kernel/blob/develop-yt113-L5.4.61/drivers/char/sunxi_g2d/g2d_bsp_v2.c
从g2d内核驱动中也可以得知,暂时没有方法为g2d设置自定义的YUV系数,g2d不适合用于JPG的编解码,但依然适合摄像头和视频编解码的颜色空间转换
吴新慧
海思Hi3093工控MPU-米尔嵌入式核心板开发板
米尔RZ/G2L开发板瑞米派双核A55Remi Pi学习板兼容树莓派扩展模块
米尔电子芯驰系列-D9-pro处理器D9360商显板-国产六核CPU
米尔首发-全志T527核心板-国产开发板,8核A55赋能边缘计算
米尔电子 瑞萨系列-RZ/G2UL核心板,通用64位工业MPU
