产品选型
ATR KM211 电源模块
ATR KM211 电源模块
The threshold switch KM211 can capture DC voltages of 10mV...200V. In order to be able to exactly set the desired limit value, the total range is divided into 6 measuring ranges as specified in the technical data...
产品分类:
品牌:
Fine adjustment in one measuring range is made by means of a trimmer in the front panel. The direction of the signal to be monitored can be separately preselected on two dip switches (+/-). When both switches are closed (state upon delivery) the comparator operates symmetrically. The switching hysteresis can be adjusted from 2...40% by means of another helical trimmer without changing the switch threshold during such adjustment.
The device have a galvanic separation wide-range power supply, that allows a connection at all usual ac and dc supply voltages (19Vdc...255Vac). They can be snap-on mounted onto support rails TS35.
MOELLER PKZ 系列电机保护开关
MOELLER塑壳断路器NZM1-4系列
MOELLER M22按钮和指示灯
MOELLER LZM系列断路器
MOELLER DIL接触器
