STEC ZeusIOPS 固态电子盘
2007/7/4 9:31:00
Zeus-IOPS系列硬盘在读取速度上可以达到企业级15000rpm硬盘的200倍,同时稳定性、功耗方面也大为降低。
产品分类:工控元器件 工控机 工控机配件 专用机 存储器 存储产品 固态电子盘
品牌:易帝
STEC(SimpleTech)公司推出的3.5英寸SSD硬盘新品,隶属于Zeus-IOPS系列,容量则分别达到了惊人的256GB/512GB(注意是“GB”而不是“MB”哦),与目前高端的传统硬盘容量相同!
STEC ZeusIOPS Solid State Drives are elite high performance advanced data storage solutions. Built for speed, the ZeusIOPS is over two hundred times faster at random I/O than standard disk drives. One ZeusIOPS drive can replace multiple hard drives or eliminate the need to purchase additional servers to overcome performance bottlenecks, resulting in reduced cost and space requirements.
Relational databases for trading, banking, purchasing and other online transactions serve data to many distributed users. In these applications where time and availability matter most, disk drive latency keeps processors and applications waiting for data. Database applications are most affected by this widening disparity in performance between servers and disk drive storage where adding more users only increases the wait for everyone. Decreasing access times to indices, frequently accessed tables, and redo logs of the database make a huge difference in database performance. Moving these critically important files to a ZeusIOPS Solid State Drive will eliminate the I/O bottleneck.
Over 200 Times Faster
IOPS than a 15K RPM
Enterprise Hard Disk Drive Drop-In Replacement for Mechanical Fibre Channel
Hard Disk Drives
Up to 200MBs/sec Sustained Throughput High-speed Fibre Channel Interface
Up to 256GB Capacity
(512GB Coming Soon) Lower cost per transaction
Low power consumption 3.5-inch Form Factor
IOPS than a 15K RPM
Hard Disk Drives
Viking 推出DDR笔记本宽温内存
AMD先发制人,携手SimpleTech合推DDR3模块对抗英特尔
VIKING(维京)DDR宽温内存芯片RoHS认证书
VIKING(维京)宽温 SD 工业级笔记本内存
STEC推出全球最薄9.5mm固态磁盘
