The 08G series Brush DC motor technoloy uses an ironless rotor combined with a commutation system using precious metal. produces 0.7 Watts of power utilizing a 5 segment precious metal commutation system. The smallest of the Portescap lineup, the 8 millimeter diameter, 19.6 millimeter length, 08G series motor provides ample power for most miniature motor applications.
This Brush DC technology uses an ironless rotor combined with a commutation system using precious metal.High acceleration, high efficiency, long life, ideal for portable or small equipments that are mostly battery operated. This product is compatible with an R10 gearbox. Please click here to see specifications or to purchase: http://www.portescap.com/product.cfm?Product_ID=36.
Product Specification Comments : Is compatible with an R10 gearbox.
Commutation : Precious Metal
Diameter : 8.0 mm
Power : 0.5 Watts
Rated Voltage : 6.0 volts
产品说明:
注释:可连接R10变速箱
整流:贵金属
直径:8毫米
功率:0.5瓦特
额定电压:6伏特
This Brush DC technology uses an ironless rotor combined with a commutation system using precious metal. High acceleration, high efficiency, long life, ideal for portable or small equipments that are mostly battery operated. This product is compatible with an R10 gearbox. Please click here to see specifications or to purchase: http://www.portescap.com/product.cfm?Product_ID=36.
Comments : Is comptaible with an R10 gearbox
Diameter : 8.0 mm
Power : 0.5 Watts
Rated Voltage : 2.0 volts
产品说明:
注释:可连接R10变速箱
整流:贵金属
直径:8毫米
功率:0.5瓦特
特定电压:2伏特
