portescap 22BHS(22毫米)无刷有槽直流电机
产品分类:电机 运动控制
品牌:Portescap
直流无刷无槽电机—22BHS(22毫米)(Brushless Slotless DC) |
Brushless Slotless DC - 22BHS (22mm)With an average 3dBA reduced noise level and 10% lower inertia, the 22BH series offers the best solution for your application. The new internal design achieves a 10% reduction in length and as much as a 400% reduction in vibation with a 10% increase in power. The decreased size and weight, combined with increased efficiency, make the 22BH series the most lightweight and energy efficient option for applications such as respirators,pumps, hand tools. • 3 lengths available: Short (S), Medium (M), Long (L) • Sensorless (3C), Hall Effect sensors (8B) Available in 2-wire version (2A) the Portescap 22BHS becomes as easy to control as a regular brush DC motor, by simply applying the appropriate voltage. To order other windings available on the specifications page, or to place a custom order, please contact your regional Customer Support team. 平均减少3Dba噪音和10% 的低惯量,22BH系列为你的使用提供最好的解决方法。新型的内部设计能够缩短10%的长度,减少高达400%的震动和增加10%的动力。 减少尺寸和重量、增加效率,使16BH系列大多数成为像小型抽水机,呼吸器,手持式工具,空气采样装置这些要求轻量化和能量高效的产品的首选。 3种可用长度:短,中等,长 无位置传感器:霍尔传感器 只要提供适当的电压,用2线电源供电的Portescap牌16BHS就能够像普通有刷直流电机那样被轻易控制。 16BHL系列产品难以在我们的官方网站购买,但可以通过电话订购。请到你所在地区的客服定购商品。 22BHS 2A CW C 01
portescap P520/P532系列(52毫米) 永磁盘式步进电机
portescap P430系列 (39毫米) 永磁盘式步进电机
Portescap P310系列(32毫米) 永磁盘式步进电机
Portescap P010系列(10毫米)永磁盘式步进电机
NMB-MAT PM10S-020 永磁式步进电机
