Portescap EBL驱动器 直流无刷电机驱动器
产品分类:电机 运动控制 执行机构
品牌:Portescap
直流无刷电机—EBL驱动器(Brushless Slotted DC) |
EBL Brushless Driver
• With a powerful speed range of 90,000 RPM, and a maximum current output of 12 amps, the amplifier provides a continuous current output of 3 amps and a supply voltage of 5.5-50 Volts. • Weighing in at under 2 oz, the new amplifier is able to provide a broad supply voltage range, which makes the driver capable of controlling the smaller 13mm BLDC motors to the larger 30mm motors. • Also noteworthy is the included thermal, short and over current protection. An optional feature allows for current limitation at start up to protect surrounding equipment, which can come in handy for things such as improving the life of a battery pack in a medical respirator, while the internal current ripple control minimizes increases in motor heat. • With increases protection and generous flexibility, this new amplifier is well suited for applications where efficiency, high acceleration and safety features are key, such as medical devices. EBL -H-50-3 [3091000016]
portescap P520/P532系列(52毫米) 永磁盘式步进电机
portescap P430系列 (39毫米) 永磁盘式步进电机
Portescap P310系列(32毫米) 永磁盘式步进电机
Portescap P010系列(10毫米)永磁盘式步进电机
NMB-MAT PM10S-020 永磁式步进电机
