产品选型
portescap Stepper Hybrid - h3 Enhanced 混合式步进电机
产品分类:
电机 运动控制 执行机构
品牌:
Portescap
Introducing the new stator-enhanced version of the h3 Series Step Motors.
These RoHS-compliant hybrid step motors are an ideal solution in medical device, semiconductor equipment and laboratory instrumentation applications.  These 1.8-degree step motors feature aluminum housing for superior heat dissipation, Neodymium iron boron magnets for optimized torque density, and a bearing retainer and o-ring to help reduce motor noise.  Larger bearings enable the motor to effectively handle higher side and radial loads.
介绍这个新型的强化定子版本的h3系列步进电机
这些适应RoHS的混合步进电机在医疗装置,半导体设备和实验室仪器的应用上是理想的电机。这些1.8度的步进电机的特点是拥有有良好散热性的铝外壳,使转矩密度最优化的钕铁硼磁铁,和能帮助减速噪音的轴承固定器和o形环。更大的轴承使电机有效地处理更高的边和径向载荷。
Enhanced h3 models special features:
• Patented enhancing magnets in the stator to provide 25+% more torque output across the entire speed range compared with original h3 models, which already deliver up to 40% more torque than traditional hybrid step motors
强化的h3型特点:
    和原始的h3型相比,横跨整个速度范围在定子上增强磁铁的专利能提供超过25+%的转矩输出,比传统的混合步进电机多40%的转矩。
Benefits:
• Reduce the size and weight of your machine without sacrificing performance
• Ability to use smaller drives
• Reduced power requirements
• Reduced overall system costs
• Increased machine throughput
好处:
     在不降低性能的前提下为你的机器减少尺寸和重量
     使用更小的驱动器
     减少功率需求
     减少全部的系统成本
     增加机器生产量
Ideal for Applications such as:
• Medical Devices
• Semiconductor Equipment
• Laboratory Instrumentation
They are available in NEMA 23 and 34 frame sizes, with various stack lengths available in each frame size.  Windings can be customized to suit individual application needs.  Contact your regional Portescap Sales Engineer today to learn more
理想应用如下:
医疗设备
半导体设备
实验室仪器
他们利用NEMA 23和34的框尺寸,和不同的栈长度用在每个框尺寸里。绕组能被定制以达到个人应用的需要。联系你所在地区的Portescap的工程师你可以了解更多。
portescap P520/P532系列(52毫米) 永磁盘式步进电机
portescap P430系列 (39毫米) 永磁盘式步进电机
Portescap P310系列(32毫米) 永磁盘式步进电机
Portescap P010系列(10毫米)永磁盘式步进电机
NMB-MAT PM10S-020 永磁式步进电机
