BCM-必陞科技 IX690E2 工业用主板
● Socket S1 Supports Mobile Turion64, Sempron Proceessors ● AMD RS690E +SB600 ● Two 200-pin SO-DIMMs up to 2GB DDR2 400/533/667/800 MHz ● VGA, DVI, 2-CH 18/24-bit LVDS ● Realtek ALC888 Supports 5.1+2-CH Audio ● Dual Realtek RTL8111C Gigabit LAN ● 1 PCI, 1 Mini-PCI Express, 1 bNAND, 1 CF ● 4 COM (5V/12V), 8 USB, 4 SATAII ● TPM 1.2, 8-bit DIO, 6W AMP ● 8 bit DIO, TPM 1.2, 6W AMP(Optional)
产品分类:工控机 工控机配件 工业母板
品牌:必陞科技
Specifications
System
●CPU Socket S1 supports mobile Turion, Turion 64, Sempron Proceessors
●FSB 200/400/600/800 MHz HyperTransport (HT)
●BIOS Award 8 Mb SPI BIOS
●System Chipset AMD RS690E +SB600
●I/O Chip Winbond W83627DHG-A
●System Memory Two 200-pin SO-DIMMs up to 2GB DDR2 400/533/667 MHz
●SSD One CompactFlash Type I/II socket
●Watchdog Timer Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
●H/W Status Monitor Monitoring CPU temperature and cooling fan status. Auto throttling control when CPU overheats
●Expansion One PCI (PCI Rev. 2.3 compliant), one bNAND, one Mini-PCI Express
●TPM Onboard Infineon SLB 9635 TT1.2 TPM chipset
●Wake Up on LAN/Ring Supports LAN and Ring modes (COM w/o power when WOR)
●S3 / S4 Yes
●SmartFan Control Supports 3 modes in Silent / Optimal Performance modes
I/O
●MIO 1x IDE, 4 x COM (4V/12V), 4 x SATAII, 1 x K/B, 1 x Mouse
●USB 8 x USB 2.0
●DIO 8-bit General Purpose I/O for 4-bit DI and 4-bit DO
Display
●Chipset IGP ATI Radeon X1250-base
●Display Memory Share System Memory , up to 256 MB
●Resolution 2048 x 1536 @ 32 bpp(@ 60Hz)
●Dual Display VGA+DVI, or VGA+LVDS, or DVI+LVDS extend mode supported
●LVDS Dual-channel 18/24-bit LVDS
●DVI Supported by RS690E
Audio
●Chipset ATI SB SB600
●Audio Codec Realtek ALC888 7.1 w/o multiple streaming 5.1+2-CH multiple streamings HD Audio
●Audio Interface Line in, Mic in , Line out
●Audio Amplifer Dual 6W TPA3005P2
Ethernet
●LAN1 Realtek RTL8111C PCI-E Gigabit Ethernet Controller
●LAN2 Realtek RTL8111C PCI-E Gigabit Ethernet Controller
Back Panel I/O Port
●Back Panel I/O Port 1X PS2 KB/Mouse / 2 x RS-232 (with 5V/12V output)
1 x VGA port / 1 x DVI port / 4 x USB 2.0/1.1
2 x LAN RJ45 port / 1 x Audio Jack (3 ports)
Internal I/O Connector
●Internal I/O Connector 2 x USB connector supports additional 4 USB ports
1 x 20-pin ATX Power connector
4 x 7-pin SATA II connectors
1 x 40 pin IDE Connector
1 x Front panel header
1 x System panel connector
1 x CPU Fan connector (DC fan support)
1 x system fan connector
1 x Digital IO header
1X LVDS connector
2 x Standard COM Headers (2X5)
1 x LVDS backlight power connector
1 x SPDIF header
1 x Amplifier
Mechanical & Environmental
●Power Type 24-pin ATX Power Supply
●Operating Temperature 0~60C (32~140F)
●Operating Humidity 0%~90% relative humidity, non-condensing
●Size (L x W) 6.69〃 x 6.69〃 (170 mm x 170 mm)
●Weight 0.88 lbs (0.4 Kg)
Ordering Information
IX690E2. AMD RS690E S1 Socket Mini-ITX Motherboard with VGA, LVDS/DVI, Audio, Dual GigaLAN, PCI, Mini-PCIe, bNAND, CF, 4 COM, 8 USB, 4 SATA II, 8-bit DIO, TPM & 6W AMP
BCM-必陞科技 CompactFlash卡
BCM-必陞科技 FCX231系列 嵌入式系统
BCM-必陞科技 FCX230系列 无风扇嵌入式系统
BCM-必陞科技 ECX331系列 嵌入式系统
BCM-必陞科技 ECX330系列 嵌入式系统
