产品选型
UTM-30LX机器人专用传感器
UTM-30LX机器人专用传感器
2009/12/18 14:18:34
机器人专用传感器 深圳市湘聚实业有限公司 http://www.sunet.net.cn
产品分类:
品牌:
30m and 270° scanning range. Suitable for robots with higher moving speed because of the longer range and fast response.
Feature
  • Long Detection range: 30m
  • Wide Angle: 270°
  • Outdoor Environment
  • Compact and Light: W60xD60xH87mm, 370g
Specifications
Model No.
UTM-30LX
Power source
12VDC±10%(Current consumptlon:Max:1A,Normal:0.7A)
Light source
Semiconductor laser diode(λ=785nm)
Laser safety Class 1(FDA)
Detection Range
0.1 to 30m(White Square Kent Sheet 500mm or more),Max.60m
270°
Accuracy
0.1 to 10m:±30mm, 10 to 30m:±50mm*1
Angular Resolution
0.25°(360°/1,440 steps)
Scan Time
25msec/scan
Sound level
Less than 25dB
Interface
USB2.0(Full Speed)
Synchronous output
NPN open collector
Command system
Exclusively designed command SCIP Ver.2.0
Connection
Power and Synchronous output:2m flying lead wire
USB:2m cable with type-A connector
Amblent(Temperature/Humidity)
-10 to +50 degrees C, less than 85%RH(without dew and frost)
Vibration Resistance
Double amplitude 1.5mm 10 to 55Hz, 2 hours each in X, Y and Z direction
Impact Resistance
196m/s2, 10 times in X, Y and Z direction
Weight
Approx. 370g(with cable attachment)
*1.This accuracy could be less reliable if the sensor receives strong light such as sun light directly in the outdoor environment.
Note) This sensor is not a safety device/tool.
Note) This sensor is not for use in military applications.
External dimension
SANYO DENKI系列交流伺服电机
阿尔法 齿轮条
台湾聚盛VGM PG系列行星式减速机
SANYO山洋 R系列伺服电机
德国REXROTH力士乐 电子控制解决方案
