华纳电气全国总代理 超越离合器
2009/12/24 14:45:09
全国总代理超越离合器 深圳市伟纳仕电气有限公司 http://www.warnerelec.com
产品分类:品牌:
超越离合器 支持球状轴承设计
![]() 球轴承的设计提供了支持许多不同的安装配置,灵活变通的方案。 在自给自足的球轴承容纳最径向和轴向负荷的应用现状。 ![]() FSO 系列 General purpose, ball bearing clutches suitable for the largest variety of overrunning applications with torque capacities up to 27,000 lbft. Oil and grease lubrication are available. FS/FSO-C/T 系列 General purpose, ball-bearing clutches suitable for the largest variety of overrunning applications with torque capacities up to 27,000 lbft. C/T sprag clutches are ideal for applications with high speed outer race overrunning and low speed driving. C/T clutches are available with oil lubrication only. ![]() FS-100, 200, 300 系列 Can be used as overrunning clutches where a compact package is desired, however, are generally used as indexing clutches. A snap-ring bearing must be inserted before installing. An adequate seal or cover must be provided at the open end to retain lubricant. Shaft end must be turned down and threaded to accommodate a bearing and lock nut. ![]() FS 系列 General purpose, ball bearing clutches suitable for overrunning applications with torque requirements from 7,000 lbft to 27,000 lbft. They are oil lubricated. ![]() FSA 系列 FSA model clutches are designed for lower speed overrunning applications in the torque range from 38,000 to 500,000 lbft. FSA clutches are oil lubricated and equipped with lip-type seals. |
STIEBER CSK-P型/CSK-PP型超越离合器
STIEBER CSK-2RS系列超越离合器
注塑机专用伺服系统驱动产品及系统
路斯特ServoC 操作手册(中文)
路斯特注塑机专用伺服系统
