圣邦微电子 SGM9125 5通道标准视频滤波器
产品指标 通道数 5-Channel 关断 N 电源电压(V) 3.3 to 5.5 固定增益(dB) 6 -3dB带宽(MHz) 8 压摆率(V/μs) 35 静态电流(mA) 44 最小电源抑制比(dB) 51 最小共模抑制比(dB) 温度范围(℃) -40 to 85 轨到轨输入 N 轨到轨输出 Y 封装形式 TSSOP14
产品分类:嵌入式系统
品牌:产品介绍
产品描述 |
The SGM9125 is a low-Voltage, 5-Channel video amplifier with integrated reconstruction filter and input clamps. Specially suited for standard definition video signals, this device is ideal for a wide range of television and set-top box applications. SGM9125 offers 6dB Gain rail-to-rail output driver and 5th order output reconstruction filter on all five channels. It has 8MHz -3dB bandwidth and 35V/μs slew rate. SGM9125 provides improved image quality compared with passive LC filters and discrete drivers solution. Operating from single power supply ranging from 3.3V to 5.5V and sinking an ultra-low 44mA quiescent current, the SGM9125 is ideally suited for battery powered applications. SGM9125 can be DC-coupled or AC-coupled with input video signal, such as the output stage of DAC to eliminate out-of-band noise. The output in SGM9125 can be configured as DC or AC-coupled output. The SGM9125 is available in Green TSSOP14 package. It operates over an ambient temperature range of |
产品特性 |
Ÿ 5-Channel 5th Order 8MHz (SD) Filters Ÿ Transparent Input Clamping Ÿ 6dB Output Driver Gain
![]() ![]() ![]() ![]() ![]() ![]() 提交
圣邦微电子 SGM8041超低功耗运算放大器 圣邦微电子 SGM8141超低功耗运算放大器 圣邦微电子推出多功能微处理器监测产品SGM706/SGM708 SGM706 Low-Cost, Microprocessor Supervisory Circuit 圣邦微电子 SGM8045运算放大器 |
