产品选型
研扬 AEC-6410无风扇嵌入式控制器
研扬AEC-6410无风扇嵌入式控制器紧凑型设计,外观小巧,强固性构造,低功耗,PC/104扩展。
产品分类:
嵌入式系统
品牌:
研扬科技
Due to the growing popularity from the IPC market, the newest Boxer series AEC-6410 has been introduced by AAEON. AEC-6410 utilizes an AMD Geode processor.
New Innovation for Entertainment Multimedia Domain
In this era of information explosion, the advertising of consumer products will not be confined to the family television, but will also spread to high-traffic public areas, like department stores, the bus, transportation station, the supermarket etc. The advertising marketing industry will resort to every conceivable means to transmit product information to consumers. System integrators will need a multifunction device to satisfy commercial needs for such public advertising.
Stable Design for Rugged Environment
The AEC-6410 is designed for rugged environments due to the following reasons; first, it can withstand tough vibration testing up to 5g rms. With the anti-vibration hard drive device option, the AEC-6410 can be used in high vibration environments. In addition, the AEC-6410 offers low power consumption system that while operating in ambient temperatures ranging from 0° to 45°C. The MTBF(Mean Time Before Failure) rating states that the AEC-6410 can operate up to 70,000 hours at 35°C ambient temperature, which indicates its careful and long-life design.
The AEC-6410 is a standalone high performance controller designed for long-life operation and with high reliability. It can replace traditional methods and become the mainstream controller for the multimedia entertainment market.
系统
  • 处理器: AMD Geode LX800 500MHz 处理器
  • 系统内存: DDR SODIMM x 1, 最大512MB(DDR 400)
  • VGA/ 键盘/鼠标: VGA x 1, USB键盘鼠标
  • 以太网: 10/100Base-TX, RJ-45 x 2
  • SSD: 板载CF插槽 x 1
  • 硬盘存储: 选配HDD工具包
  • 串口: COM x 2 (COM1: RS-232, COM2: RS-232/422/485)
  • 音频: Line-out x 1, MIC in x 1, Line -in x 1
  • USB: USB2.0 x 4
  • 系统控制: 电源开关 x 1
  • LED 指示灯: 系统 LED x 1, HDD LED x 1
  • 监视定时器: 可通过软件编程超时中断或系统复位
  • 电源:DC 12V 输入
  • 功耗:AMD LX 800     0.86A@DC 12V
  • MTBF (小时):40,000
  • 操作系统: Windows XP, XP Embedded, WinCE, Linux
结构
  • 构造:铝挤型外壳
  • 颜色:灰色/ 深蓝色
  • 安装:壁挂式
  • 尺寸: 7.1" (W) x 2.6" (H) x 4.7" (D) (180mm x 66mm x 119mm)
  • 包装尺寸: 12" (W) x 9.45" (H) x 7.9" (D) (305mm x 240mm x 200mm)
  • 总重: 6.16 lb (2.8 Kg)
  • 净重: 2.42 lb (1.1 Kg)
环境
  • 工作温度: 0oC ~ 40oC (32oF ~ 104oF) ( LX 800/CF )
  • 存储温度: -10oC ~ 60oC (14oF ~ 140oF)
  • 存储湿度: 5~95% @ 40oC, 无冷凝
  • 振动: 5 grms/ 5~500Hz/ 随机运行 - CF
  • 冲击: 50g峰值加速度(持续时间11msec. ) - CF
  • EMC: CE/ FCC Class A
官宣!研扬人工智能馆盛大开业啦~
研扬科技BOXER-6405U智能边缘计算平台
研扬科技 | 应用案例分享 || 将边缘计算引入面部识别应用
研扬科技 | FWS-8600网络设备为人工智能网络和数据中心注入新动力
研扬科技 | 由英特尔酷睿处理器驱动的紧凑型完整解决方案
