产品选型
研扬 AEC-6831无风扇嵌入式控制器
研扬 AEC-6831无风扇嵌入式控制器支持Intel Atom N270处理器,千兆以太网 x 2,宽幅DC输入,COM x 2, USB x 4,Mini-PCI x 1,AT电源模式,宽温工作。
产品分类:
嵌入式系统
品牌:
研扬科技
The AEC-6831 is an Embedded Control PC with Intel Atom Processor. The Anti-vibration and high temperature tolerances are the main design features of the AEC-6831. This allows the AEC-6831 to be installed in a rugged transportation environment despite high ambient vibration and temperature.
In addition to the Atom CPU, the AEC-6831 have DVI + VGA output for video output and DC power supply is commonly used in most vehicles and factory equipments, the AEC-6831 can powered by a DC 9~30V input with low power consumption and high performance. You can also choose an additional external AC power adapter for power redundancy purposes.
Transportation has become part of most people's life and forms a necessary part of their lifestyle. From cars to trains to ships, we rely on those tools a lot. The AEC-6831 is designed to improve
transportation control and enhance the quality of our lives.
系统
  • 处理器
    IntelR Atom? N270 1.6GHz处理器
  • 内存(选配)
    DDRII SODIMM x 1, 最大1GB
  • VGA/ 键盘/ 鼠标
    VGA x 1, DVI-I x 1; USB键盘/鼠标
  • 以太网
    10/100/1000Base-TX, RJ-45 x 2
  • SSD
    Type II CF插槽 x 1
  • 硬盘存储
    2.5" SATA/IDE 硬盘驱动架 x 1 (选配)
  • COM
    COM x 2
  • 音频
    Line-in x 1, Line-out x 1, Mic x 1, 需要1条延长线
  • USB
    USB2.0 x 4
  • 系统控制
    电源开关 x 1, 复位按钮 x 1
  • LED指示灯
    电源LED x 1, HDD active LED x 1
  • 监视定时器
    可通过软件编程超时中断或系统复位
  • 供电方式
    1. DC输入
    内置DC-DC转换器(默认)
    输入电压: DC 9-30V
    2. AC输入
    外置电源适配器 (选配)
    输入电压: AC 100~240V@50~60 Hz
  • 功耗
    Intel® Atom™ N270 1.6 GHz
    1.47A @ DC 9V
  • MTBF (小时)
    60,000
  • 操作系统
    Windows® XP Pro for Embedded, Windows® XPE, Linux, Windows® 7
结构
  • 构造
    铝挤型外壳
  • 颜色
    深蓝色
  • 安装
    壁挂式
  • 尺寸
    9.5" (W) x 2.5" (H) x 4.2" (D) (240 mm x 64 mm x 107 mm)
  • 包装尺寸
    12" (W) x 7.87" (H) x 9.45" (D) (305 mm x 200 mm x 240 mm)
  • 净重
    4.75 lb (2.16 kg)
环境
  • 工作温度
    5°F ~ 131°F (-15°C ~ 55°C) (CF)
    32°F ~ 122°F (0°C ~ 50°C) (HDD)
  • 存储温度
    -4°F ~ 158°F (-20°C ~ 70°C) (CF)
  • 存储湿度
    5~95% @ 40oC,无冷凝
  • 振动
    5g rms/ 5 ~ 500Hz /运行状态 (CF)
    1g rms/ 5~ 500Hz /运行状态(HDD)
  • 冲击
    50G峰值加速度(持续时间11 msec.) (CF)
    20G峰值加速度(持续时间11 msec.) (HDD)
  • EMC
    CE/ FCC class A
官宣!研扬人工智能馆盛大开业啦~
研扬科技BOXER-6405U智能边缘计算平台
研扬科技 | 应用案例分享 || 将边缘计算引入面部识别应用
研扬科技 | FWS-8600网络设备为人工智能网络和数据中心注入新动力
研扬科技 | 由英特尔酷睿处理器驱动的紧凑型完整解决方案
