研扬 AEC-6510 无风扇嵌入式控制器
2010/5/28 13:18:17
研扬 AEC-6510 无风扇嵌入式控制器支持AMD LX800处理器,IP65防护,COM x 2/ VGA/ LAN/ USB,外观小巧,强固型结构,低功耗,内置连接器。
产品分类:嵌入式系统
品牌:研扬科技
The AEC-6510 is designed for rugged environments due to the following reasons; first, it can withstand tough vibration testing up to 5g rms. With the anti-vibration hard drive device option, the AEC-6510 can be used in high vibration environments. In addition, the AEC-6510 offers low power consumption system that while operating in ambient temperatures ranging from -20° to 70°C. The MTBF(Mean Time Before Failure) rating states that the AEC-6510 can operate up to 70,000 hours at 35°C ambient temperature, which indicates its careful and long-life design.
The AEC-6510 is a standalone high performance controller designed for long-life operation and with high reliability. It can replace traditional methods and become the mainstream controller for the multimedia entertainment market.
系统
- CPU:AMD Geode LX800 500MHz 处理器
- 内存:DDR 333/400 SODIMM × 1, 最大512MB
- VGA:DB-15 VGA 端口 × 1
- 以太网:10/100 Base-TX RJ-45 接口 × 1
- SSD:内置CF × 1
- 串口:COM1:RS-232 × 1,COM2:RS232/422/485 × 1
- USB:USB 2.0 × 1
- 监视定时器:支持
- 电源:1、DC输入:输入电压 9V DC-30V DC
2.、AC输入:外置 AC电源适配器 (选配)
输入电压:100V AC ~ 240V AC
- 电源功耗:12V@0.45A
- MTBF (Hours):70,000
- 操作系统:Windows CE 5.0, Windows XP Pro, Windows XP Embedded, Fedora Core
结构
- 构造:铝挤型外壳
- 颜色:黑色
- 安装:壁挂式
- 尺寸:275 mm (宽) x 199 mm(高) x 62 mm(深) (10.8"x 7.83" x 2.44")
- 包装尺寸:336mm(宽) × 294mm(高) × 260mm(深) (13.23" × 11.57" × 10.24")
- 净重:2.3kg(5.06 lb)
环境
- 防护等级:IP-65认证
- 工作温度:-20 ℃ ~ 70 ℃ (-4℉ ~ 158 ℉)(CFD)
- 储存湿度:5 ~ 95% @ 40 oC, 无冷凝
- 振动:5g rms / 5 ~ 500Hz / 随机工作(CFD)
- 冲击:50G 峰值加速度(持续时间11 msec.) (CFD)
- EMC:CE/FCC A级
官宣!研扬人工智能馆盛大开业啦~
研扬科技BOXER-6405U智能边缘计算平台
研扬科技 | 应用案例分享 || 将边缘计算引入面部识别应用
研扬科技 | FWS-8600网络设备为人工智能网络和数据中心注入新动力
研扬科技 | 由英特尔酷睿处理器驱动的紧凑型完整解决方案
