Leuze 劳易测 KRT 3B型传感器
劳易测电子最新推出了KRT 3B 型传感器,是我们产品系列中的新成员,它是现有产品中体积最小的色标传感器,其性能可以与同类更大体积的产品相媲美,在狭小的空间内展示其超凡的能力。
产品分类:离散传感器 其它
品牌:劳易测
在包装和自动控制技术领域如打印码的识别等场合,使用色标传感器在当今已经十分普遍了。在该类产品应用中,劳易测电子最新推出了KRT 3B 型传感器,是我们产品系列中的新成员,它是现有产品中体积最小的色标传感器,其性能可以与同类更大体积的产品相媲美,在狭小的空间内展示其超凡的能力。
KRT 3B – 体积小, 但能力非凡
目前市场上体积最小的色标传感器,对于有限的空间,KRT 3B是最明智的选择。
With the outstanding EasyTune and YellowBoost features, Leuze electronic presents the KRT 3B contrast scanners in a new 'dimension'. They are the smallest with respect to their size, but—relative to their low volume—the biggest with regard to performance.
Contrast scanners of the KRT 3B series from Leuze electronic distinguish between grayscale values, enabling them to detect minimal contrasts. As a result, a check can be performed for the presence of text or imprints or socalled marks detected. With the new KRT 3B devices, all three transmitter models—RGB light, white light and laser light—are available in an exceptionally small construction. In addition to the standard design, the sensors are also available in stainless steel, in the proven WASH-DOWN and HYGIENE designs.
The small size of the new contrast scanners belies their high performance. With extremely short response times of up to 50 µs and high repeatability, these scanners—the smallest with respect to housing volume—are actually the biggest. With regard to their configuration options, they also perform big. Here, IO link makes onsite configuration possible with unmatched simplicity and reproducibility. With the three teach processes: 2-point teach, static 1-point teach and dynamic 2-point teach, the optimum teach process is available for every type of machine use. Furthermore, the switching thresholds ascertained via teach-in can be changed during running operation in 4% increments with EasyTune. By means of this online switching-threshold correction, it is possible to quickly respond to changed process parameters without performing a new teach-in.
One special feature is YellowBoost, a form of yellow support developed by Leuze with which contrast detection of the white-light contrast scanner is optimized. Although this affects all wavelengths, smoothing of the signal deviation is strongest in the yellow-light range, hence the name of the function.
With IO link, in combination with the EasyTune switching threshold correction and YellowBoost, Leuze electronic has implemented globally unique features in the smallest—and yet biggest—contrast scanner to date.
仅需一部传感器,安全功能一网打尽
物流工程分会,物流与仓储机械分会携手劳易测电子于深圳召开2019年年会
劳易测电子亮相2019德国纽伦堡SPS工业自动化展
劳易测电子为百威啤酒举办安全标准交流会
打卡CeMAT ASIA 2019,带您领略劳易测电子展台风采
