瑞科RIKO RN05-N RN04-N RN04-N2 RN04-P RN05-N2 接近开关
2011/7/23 16:47:57
RN05-N 接近开关,感应距离5mm,npn输出。
产品分类:离散传感器 物联网 接近开关 感知层 位置检测
品牌:产品介绍
台湾瑞科RIKO RN05-N 接近开关现货供应
Output mothod |
NPN N.O. | RN05-N | RN05-ND1 |
NPN N.C. |
RN05-N2 |
PNP N.O. |
RN05-P |
RN05-PD1 | |
PNP N.C. | RN05-P2 | - | |
Deion |
Top surface | ||
Standard sensing object | Iron 18 x 18 x 1mm | ||
Sensing distance | 5 mm | ||
Secure sensing distance | 0 to 4 mm | ||
Hysteresis | ≦ 10 % of sensing distance | ||
Response time | 2 ms Max. | ||
Operating voltage | DC10 ~ 30 V | ||
Current consumption | ≦ 8 mA no-load | ||
Load current | 100 mA Max at DC 30V | ||
Leakage current | ≦ 1.1 mA no-load | ||
Residual voltage | ≦ DC 1.5V | ||
Insulation resistance | 20M Ω min. (DC500V) | ||
Voltage withstandability | AC1000V 60Hz for 60 Sec. | ||
Operating temperature | -20℃ ~ + 60℃ | ||
Protection degree | IP 64 | ||
Wiring method | Pre-wire Ø4.2 x 2M / 3-wires | M8 connector | |
Weight | Approx. 60g | Approx. 12g |
Dimensions
中国台湾KINTON精通接近开关感应器KX-W1
KUDOM库顿单相交流输出固态继电器KSI480D60-L
中国台湾TPC亚鸿接近开关JD-1705E1-C50
VMMORE微秒伺服驱动器ISD300-S25A-043
STUOB思拓邦圆柱形电感式接近传感器HX-1204-E1
