产品选型
瑞科ROKO SC1204-KP2接近开关
瑞科ROKO SC1204-KP2,瑞科ROKO SC1204-KP2,瑞科ROKO SC1202-KP2
产品分类:
品牌:
瑞科ROKO SC1204-KP2,SCS0802-N接近开关现货,規格表(SCS短管/SC正規品/SCL長管)
Output mothod 輸出模式 NPN N.O. SC□1204-N SC□1204-ND SC□1204-ND1
NPN N.C.
SC□1204-N2
SC□1204-N2D SC□1204-N2D1
PNP N.O.
SC□1204-P
SC□1204-PD SC□1204-PD1
PNP N.C. SC□1204-P2 SC□1204-P2D SC□1204-P2D1
NPN N.O./N.C.
PNP N.O./N.C.
SC1204-KP2
SCR N.O. SC1204-A
SCR N.C. SC1204-A2
Sensing surface / 檢測方向 Unshielded / 非隔離型
Description / 外型 Standard / 標準M12
Standard sensing object / 標準檢測物 Iron 12 x 12 x 1 mm
Sensing distance / 檢出距離 4 mm
Secure sensing distance / 建議距離 0 to 3.2 mm
Hysteresis / 遲滯 ≦ 10 % of sensing distance
Response time / 反應時間
DC Type 2 ms Max. or AC Type 50ms
Operating voltage / 工作電壓 DC 12 ~ 24V or AC90 ~ 260 V
Current consumption / 消耗電流 DC : ≦ 8 mA no-load or AC : 2 mA Max
Load current / 負載電流 DC : 100 mA Max at DC 24V or AC : 5 ~ 300 mA Max
Leakage current / 漏電流 ≦ 1.1 mA no-load
Residual voltage / 殘餘電壓 ≦ DC 1.5V
Insulation resistance / 隔離阻抗 20MΩ min. (DC500V)
Voltage withstandability / 絕緣耐壓 AC1000V 60Hz for 60 Sec.
Operating temperature / 工作溫度範圍 -20℃ ~ + 60℃
Protection degree / 防水等級 IP 66
Wiring method / 出線方式 N/P : Ø4.2x 2M / 3-wires
KP2 :Ø4.2x2M / 4-wires
AC :Ø4.2x2M / 2-wires
M8 pigtailed type
/ M8 接頭15cm電線式
M12 plug-in connector type
/ M12 接頭
Weight / 重量 SC Approx. 65g Approx. 15g Approx. 20g
SCL Approx. 70g Approx. 20g Approx. 25g
SCS Approx. 60g Approx. 15g Approx. 20g
Output mothod 輸出模式 NPN N.O. SC□0801-N SC□0801-ND SC□0802-N SC□0802-ND
NPN N.C. SC□0801-N2 SC□0801-N2D SC□0802-N2 SC□0802-N2D
PNP N.O. SC□0801-P
SC□0801-PD SC□0802-P
SC□0802-PD
PNP N.C. SC□0801-P2 SC□0801-P2D SC□0802-P2 SC□0802-P2D
NPN N.O./N.C.
PNP N.O./N.C.
SCR N.O.
SCR N.C.
Sensing surface / 檢測方向 Shielded / 隔離型 Unshielded / 非隔離型
Description / 外型 Standard / 標準M8
Standard sensing object / 標準檢測物 Iron 8 × 8 × 1 mm
Sensing distance / 檢出距離 1 mm 2 mm
Secure sensing distance / 建議距離 0 to 0.8 mm 0 to 1.6 mm
Response time / 反應時間 1 ms Max.
Operating voltage / 工作電壓 DC12 ~ 24 V
Current consumption / 消耗電流 ≦ 8 mA no-load
Load current / 負載電流 100 mA Max
Wiring method / 出線方式 Pre-wired Ø3 x 2M
/ 3-wires
M8 pigtailed type
/ M8接頭15cm電線式
Pre-wired Ø3 x 2M
/ 3-wires
M8 pigtailed type
/ M8接頭15cm電線式
Weight / 重量 Approx. 30g Approx. 12g Approx. 30g Approx. 12g
Output mothod 輸出模式 NPN N.O. SC□1202-N SC□1202-ND SC□1202-ND1
NPN N.C.
SC□1202-N2
SC□1202-N2D SC□1202-N2D1
PNP N.O.
SC□1202-P
SC□1202-PD SC□1202-PD1
PNP N.C. SC□1202-P2 SC□1202-P2D SC□1202-P2D1
NPN N.O./N.C.
PNP N.O./N.C.
SC1202-KP2
SCR N.O. SC1202-A
SCR N.C. SC1202-A2
Sensing distance / 檢出距離 2 mm
Secure sensing distance / 建議距離 0 to 1.6 mm
DC Type 1 ms Max. or AC Type 50ms
M8 pigtailed type
/ M8 接頭15cm電線式
/ M12 接頭
Honeywell SZL-WLC-A,SZL-WLC-B 限位开关
霍尼韦尔 SZL-WL-A,SZL-WL-B 行程开关
霍尼韦尔 SZL-VL-I,SZL-VL-B 行程开关
霍尼韦尔 SZL-VL-A 行程开关
honeywell SZL-VL-S-J,SZL-VL-J行程开关
