JOGLER 磁致伸缩液位计
2012/4/12 14:54:31
Jogler’s MG-Series magnetic level indicator is a proven and cost effective method to accurately monitor and control liquid level requirements in any process environment. MG-series level indicators can be designed and installed on any tank or vessel for extreme operating conditions, low density, corrosive or hazardous materials.
产品分类:物联网 仪器仪表 物位/液位仪表 现场仪表 感知层 液位计 物液位传感器
品牌:产品介绍
materials.
All MG-series magnetic level indicators are
comprised of a chamber, internal magnetic
float and external indicator. The internal
float, located within the chamber, maintains
a constant magnetic circuit with the external
indicator. As the float reacts to fluctuating liquid
levels within the adjoining tank, the external
indicator responds to the rising or falling
motion of the float, which provides an indirect
level indication of the tank.
The Chamber is non-ferrous and can be
fabricated to any length up to 20 feet with a
standard specification of 2.00 inch, Schedule
40. Larger diameter and higher rated chambers
are available depending upon application
requirements. Jogler’s MG-series magnetic
level chambers are fully rated to ASME B31.1
& B31.3 boiler and process piping codes.
The internal magnetic float is engineered
and designed for the minimum density of the
process media at the maximum operating
conditions. Each float contains a rotating
360° magnetic assembly which is generates a
strong and balanced magnetic circuit with the
external indicator.
The external indicator is hermetically sealed
and is available in Wide Flag or Single Tracker
styles. Each indicator type contains its own
magnetic assembly that is balanced with the
internal float. This generates a strong magnetic
circuit that ensures an accurate and constant
level indication.
materials.
external indicator.
level indication.
罗克韦尔-AB Kinetix 1326AB 伺服电机 (1326AB-B720E-S2L)
罗克韦尔-AB Kinetix Ultra5000 智能伺服驱动器 (2094-BC02-M02-S)
罗克韦尔-AB SMC-3 智能马达控制器(150-B180NBDB)
美国进口JOGLER高压浮球
美国JOGLER进口磁翻板浮球
