JOGLER 磁翻板液位计
9715 Derrington Road Houston, TX 77064 P: 281.469.6969 F: 281.469.0422 TF: 800.223.8469 www.Jogler.com sales@Jogler.com Jogler’s MGT-6000 series liquid level transmitter is the latest development in magnetostrictive liquid level sensing technology that is designed exclusively for magnetic level indicators. The MGT-6000 contains a low profile waveguide that is mounted away from the level gage chamber. This design isolates the dual sealed waveguide from excessive vibration and temperature. From enhanced sensor technology, the output signal is very sensitive, fast, stable and accurate. The MGT-6000 can be mounted and retrofitted to most magnetic liquid level indicators.
产品分类:物联网 仪器仪表 物位/液位仪表 现场仪表 感知层 液位计 物液位传感器
品牌:产品介绍
• 24 VDC nominal, two wire, loop powered
• LCD display in 4-20 mA, in/cm and/or percent output signal
• Local and remote detection for total or interface elevations
• HART protocol field communication
• Local programmability allows for easy parameter changes
• Quick-Cal function for simple recalibration to any span
• Non wetted, dual sealed 316 SS low profile waveguide
• Isolated from excessive process temperature & vibration
• Top, bottom or remote transmitter head mounting locations
• Short offset mounting dimension of 7.00 inches
• Accuracy of 0.01% of total span from enhanced sensitivity
• Very durable with a strong, stable & noise free output
• State of the art sensor and transmitter electronics
• Unique transmitter puck design for ease of installation
• Maximum transmitter length of 20 feet
• Will retrofit to most magnetic level indicators
• Capable of extreme process operating temperatures
• Explosion proof housing, NEMA Type 4X
• Class I, Division 1, Groups B, C, D
• Class II, Division 1, Groups E, F, G: Class III
罗克韦尔-AB Kinetix 1326AB 伺服电机 (1326AB-B720E-S2L)
罗克韦尔-AB Kinetix Ultra5000 智能伺服驱动器 (2094-BC02-M02-S)
罗克韦尔-AB SMC-3 智能马达控制器(150-B180NBDB)
美国进口JOGLER高压浮球
美国JOGLER进口磁翻板浮球
