产品选型
集智达 NISE 3142M2E嵌入式工控机
支持Intel® Core? 2 Duo/ Celeron® 处理器 双Intel® 82574L千兆以太网端口 双DVI-D独立显示 5 x RS232,1 x RS232/422/485,带自动方向控制 外接一个可锁的CFast插槽(SATA接口) 支持16V 到 30V直流电源输入 支持ATX电源模式和PXE/网络唤醒/LAN Teaming功能
产品分类:
嵌入式系统 工控机 工控机整机
品牌:
集智达智能
主板
NISB6142 Support Intel® Core? 2 Duo processor T9400 (6M cache, 2.53GHz, 1066MHz FSB) Support Intel® Core? 2 Duo processor P8400 (3M cache, 2.26 GHz, 1066MHz FSB) Support Intel® Celeron® processor 575 (1M cache, 2.0GHz, 667MHz FSB)
内存
2x 240-pin DIMM, up to 4GB DDR3 800/1066 MHz SDRAM, un-buffered and non-ECC
芯片
Intel® GM45 graphics and Memory Controller Hub Featuring the mobile Intel® Graphics Media Accelerator 4500MHD Intel® 82801IEM I/O (ICH9M-E) Controller Hub
前置I/O界面
ATX power on/off switch HDD access/power status LEDs 1x front access CFast card socket (SATA interface) 2x USB2.0 ports
后置I/O界面
2-pin remote power on/off switch 2-pin system signal 16~30V DC input 2x DB9, COM5 & COM6, RS232 1x DB44 serial port for 4x RS232 (COM2: RS232/422/485 with Auto Flow Control) 2x GbE LAN ports (support WoL & LAN teaming) 4x USB2.0 ports 2x DVI-D port 1x speaker-out and Line-in
存储
1x 2.5” SATA HDD drive bay 1x external locked CFast card socket (SATA interface)
扩展槽
One PCI expansion (10W max./ per slot) One PCIe x1 expansion (10W max./ per slot) Add-on card length:
169 mm max. with HDD installed
电源输入
ATX power mode On-board DC to DC power support from 16V to 30VDC Optional power adapter
尺寸
195mm(W)x 268mm(D)x 101mm(H) (7.7”x 10.5”x 3.98”)
构造
Aluminum chassis with fanless design
运行环境
Operating temperature:
Ambient with air flow: -5°C ~ 55°C
(According to IEC60068-2-1, IEC60068-2-2, IEC60068-2-14) Storage temperature: -20°C ~ 80°C Relative humidity: 10% to 93% (non-condensing) Shock protection: 20G, half sine, 11ms, IEC60068-2-27 Vibration protection
Random: 0.5Grms @5~500 Hz according to IEC68-2-64
Sinusoidal: 0.5Grms @5~500 Hz according to IEC68-2-6
认证
CE approval FCC Class A
上交会商用密码展|集智达商用密码硬件平台为商密建设助力
深圳网络安全展,集智达收获青睐载誉而归
聚以致远 共行万里 集智达携手绿盟探索网络安全新机遇
集智达&网迅续签战略合作:携手共进,合作共赢!
集智达RK3568处理器的MXM接口核心板GME-3601
