集智达 NiceE-6149 无风扇工控机
Onboard Intel? AtomTM Processor D2550, 1.86 GHz ● Front access expansion slot opening ● RS-232 / 422 / 485 function preset with BIOS 1x 2.5” drive bay 1x CFast socket, 1x Mini PCI-E socket, 4x USB 2.0, 2x GbE ports
产品分类:工控机 工控机整机
品牌:集智达智能
CPU |
Intel? AtomTM Processor D2550 1.86 GHz, 1MB Cache |
Chipset |
Intel? NM10 PCH |
Memory |
1x DDR3 non-ECC SODIMM, 800 MHz~1066 MHz, up to 4GB |
Network |
2x Realtek 8111E-VL GbE controller |
Expansion Slots |
1x PCI or 1x PCI -E(x16) (x1 signal) |
Storage |
1x 2.5” SSD drive bay, 1x CFast socket |
USB |
2x USB 2.0 ports on front panel2x USB 2.0 ports on rear panel |
SerialI/O |
COM1~4, COM5~6(optional) Hardware Monitor: Thermal, Voltage, Fan Header |
VGA |
CPU built-in Graphics Core 1x DVI-I, 1x 24-bit single channel LVDS |
LED |
Power / HDD ActivityRS232 / RS422 / RS485 Indicator |
Power Supply |
+12~24V DC-In Terminal Block or Power Jack |
Dimensions |
250mm(W) x 64mm(H) x 162mm(D) |
Operating Temperature |
0°C~ 45°C (32°F~113°F) |
Storage Temperature |
-20° ~ 70°C (-4°F~158°F) |
Relative Humidity |
5~95% @ 45°C, (non-condensing) |
Certification |
CE, FCC |
上交会商用密码展|集智达商用密码硬件平台为商密建设助力
深圳网络安全展,集智达收获青睐载誉而归
聚以致远 共行万里 集智达携手绿盟探索网络安全新机遇
集智达&网迅续签战略合作:携手共进,合作共赢!
集智达RK3568处理器的MXM接口核心板GME-3601
