产品选型
集智达 ATX-9880主板
集智达 ATX-9880主板
支持第二代Intel® Core?桌上型处理器 最大支持32 GB4 x DDR3 DIMM 支持VGA + DVI双显 2 x Intel® Gigabit Ethernet 支持Intel® AMT 7.0 1x PCIe X16( with PCIe X8 signals), 1x PCIe X8( with PCIe X1 signals), 1xPCIe X4(with PCIe x4 signals) slot, 1xPCIe X4(with PCIe x1 signals) slot 支持SATA 3.0, 2x RS232
产品分类:
工控机 嵌入式系统
品牌:
集智达智能
U
LGA1155,第二代Intel® Core? 桌上型处理器
内存
4 x 240-pin DIMM, for up to 32GB dual channel non-ECC un-buffered DIMM 1066/1333 SDRAM
芯片
Intel® Q67 Platform Controller Hub
BIOS
AMI BIOS Plug and play support
板载LAN
1 x Intel® 82579LM PHY for AMT 7.0 1 x Intel® 82583 PCI Express Gigabit Ethernet Support boot from LAN (PXE) 2 x RJ45 with LED
显示
2nd generation Intel® Core? Desktop processors Integrated HD graphics 1x VGA 1x DVI-D
扩展
1x PCIe X16 ( with PCIe X8 signals) slot 1x PCIe X8 ( with PCIe X1 signals) slot 1x PCIe X4 ( with PCIe X1 signals) slot 1x PCIe X4 ( with PCIe X4 signals) slot
边缘I/O界面
1x dual stack mini DIN 6-pin connector for PS2 KB/MS 1x dual stack DB9 male connector for COM1 & COM2 1x DVI + DB15 female connector VGA 2x RJ45 with dual stack USB connectors Line-In/Line-Out/MIC phone jack
I/O界面
USB 2.0: 10 ports (6 on board pin header, 4 with type A connector for external) Serial port: 2 port, with 2x5pin headers (COM 1 and COM 2) SATA HDD: 6 ports, port 1, 2 support SATA 3.0, port 3, 4, 5, 6 support SATA 2.0 Support RAID 0/1/5/10 and Intel® Matrix Storage IrDA: on board pin header GPIO: Supports 4 sets general purpose I/O each with TTL level (5 V) interface On-board buzzer x 1 Power LED/Power On/Reset/HDD LED pin header 1 x 4-pin fan connector (for CPU); 2 x 3-pin fan connectors (for System) On-chip RTC with battery backup 1 x External Li-lon battery
系统监控
4 Voltages (+3.3V, +5V, +12V, Vcore) 2 Temperatures (For CPU and System) 3 FAN speed monitors (1 for CPU and 2 for System FAN)
电源输入
Support ATX power supplies Standard ATX 24-pin connector for +12V/ +5V/ +3.3V/ +5Vsb/ -12V ATX 8-pin connector for +12V
尺寸
Micro ATX Dimension: 244mm (L) x 244mm (W)
运行环境
Board level operating temperatures: 0°C to 60°C Storage temperature: -20°C to 85°C Relative humidity: 10% to 90%, (Non-condensing)
认证
CE approval FCC Class A
上交会商用密码展|集智达商用密码硬件平台为商密建设助力
深圳网络安全展,集智达收获青睐载誉而归
聚以致远 共行万里 集智达携手绿盟探索网络安全新机遇
集智达&网迅续签战略合作:携手共进,合作共赢!
集智达RK3568处理器的MXM接口核心板GME-3601
