爱浦电 WD5-24S05A1电源模块
WD5-24S05A1电源模块典型性能: 宽输入电压2:1(最高:最低) 转换效率典型82% 宽工作温度范围:-40~85℃ 输入与输出隔离电压:1500Vdc 输出短路、过流保护(自动恢复)
产品分类:工业电源
品牌:产品介绍
产品类型:WD3-5W(A1)系列
产品型号:WD5-□S*A1
封装尺寸:25.4 × 25.4 × 10.16mm
输出功率:5 W
输入电压:9-18Vdc
输出电压:5,12,24,±5,±12,±24Vdc
详细介绍:
以下产品参数仅展示文字类资料,如需要更详细图文资料文档,请下载上方PDF文档参考阅读!
典型性能 Typical performance |
◆ 宽范围输入Wide Input voltage range (2:1) |
◆ 转换效率(典型82%)Typical Efficiency 82% |
◆ 开关频率Switching frequency:300KHz |
◆ 长期短路保护,自动恢复Short circuit protection, Self-furbish |
◆ 输入与输出高隔离Input-output isolate |
◆ PCB板上直插式安装Board in-line type installs |
◆ 金属外壳,输出纹波低 Metal case, Low Output Ripple |
技术参数 测试条件:如无特殊指定,所有参数测试均在标称输入电压、纯阻性额定负载及25℃室温环境下测得。 Technology parameter Test condition: General Nominal Line, Tc=25℃,Rated resistant load unless other wise specified. |
输入特性 Input |
Min(v) |
Nom(v) |
Max(v) |
Notes |
输入电压Vdc Input voltage |
4.5 |
5 |
9 |
2:1 |
9 |
12 |
18 |
2:1 |
18 |
24 |
36 |
2:1 |
36 |
48 |
72 |
2:1 |
72 |
110 |
144 |
2:1 |
遥控端Remote ON/OFF |
无遥控端 Non |
输入欠压保护 Input undervoltage protection |
低于低端输入电压,电源关断输出,自动恢复 Lower than the low-input voltage protection ,Self-furbish |
输出特性 Output |
输出电压精度Voltage accuracy |
Vo1,Vo2 |
±1.0%, ±2.0% |
源效应Line regulation |
标称负载,全电压范围 Nominal Load, full voltage range |
Vo1,Vo2 |
±0.2%, ±1.5% |
负载效应Load regulation |
20% ~ 100%额定负载 |
Vo1,Vo2 |
±0.5%, ±4.0% |
纹波及噪声Ripple and noise |
20MHz BM 满载(Full Load) Vo≤5.0V, ≤50mVp-p; Vo≥48V, ≤180mVp-p; Other, ≤100mVp-p |
动态响应 Dynamic response |
25%的标称负载阶跃 25% Nominal load step change |
△Vo1/△t |
±4.0/500μ s% |
输出电压调节 Voltage adjust |
无调节端 Non |
启动延迟时间Turn-on delay time |
典型值 Typical value |
≤200mS |
一般特性 General |
转换效率Efficiency |
标称电压输入,满载 Nominal input, Full load |
Vo≤5.0V,80%典型Typical |
Vo>5.0V,82%典型Typical |
开关频率Switching frequency |
300KHz 典型 Typical |
最大MAX 330KHz |
工作温度Operating temperature |
自由空气对流 Free air |
工业级 Industrial Level |
-25℃ ~ +55℃ |
军品级 Military Level |
-40℃ ~ +85℃ |
储存温度Storage temperature |
-40℃ ~ +105℃ |
-55℃ ~ +120℃ |
最大壳温Max case temperature |
+100℃ |
+110℃ |
相对湿度Relative humidity |
10%~90% |
外壳材料case material |
金属壳 Metal case |
隔离电压Isolation Voltage |
输入与输出 Input-output 1500 Vdc ≤ 0.5mA/1min; 输入与外壳Input-case 500Vdc ≤ 0.5mA / 1min |
最小无故障间隔时间(MTBF) |
2X105Hrs |
典型产品列表 Typical product tabulates |
型号 TYPE |
输入电压范围 Input voltage range |
输出电压/电流(Output voltage / current) |
VO1 |
VO2 |
VO3 |
V |
mA |
V |
mA |
V |
mA |
WD3-□S3V3A1 |
5V(4.5~9V) 12 V(9~18V) 24V(18~36V) 48V(36~72V) 110V(72~144V) |
3.3V |
600mA |
WD3-□S05A1 |
5V |
600mA |
WD3-□S09A1 |
9V |
330mA |
WD3-□S12A1 |
12V |
250mA |
WD3-□S15A1 |
15V |
200mA |
WD3-□S24A1 |
24V |
125mA |
WD5-□S3V3A1 |
3.3V |
1000mA |
WD5-□S05A1 |
5V |
1000mA |
WD5-□S09A1 |
9V |
550mA |
WD5-□S12A1 |
12V |
410mA |
WD5-□S15A1
15V |
330mA |
WD5-□S24A1
24V |
210mA |
WD3-□D3V3A1 |
+3.3V |
300 mA |
-3.3V |
300 mA |
WD3-□D05A1 |
+5V |
300 mA |
-5V |
300 mA |
WD3-□D09A1 |
+9V |
165 mA |
-9V |
165 mA |
WD3-□D12A1 |
+12V |
125 mA |
-12V |
125 mA |
WD3-□D15A1 |
+15V |
100 mA |
-15V |
100 mA |
WD3-□D24A1 |
+24V |
60 mA |
-24V |
60 mA |
WD5-□D3V3A1 |
+3.3V |
500 mA |
-3.3V |
500 mA |
WD5-□D05A1 |
+5V |
500 mA |
-5V |
500 mA |
WD5-□D09A1 |
+9V |
275 mA |
-9V |
275 mA |
WD5-□D12A1 |
+12V |
205 mA |
-12V |
205 mA |
WD5-□D15A1 |
+15V |
165 mA |
-15V |
165 mA |
WD5-□D24A1 |
+24V |
100 mA |
-24V |
100 mA |
注:□ 代表输入电压标称值,因篇幅有限,以上只是部分产品列表,若需列表以外产品,请与本公司销售部联系。 □ Shows the nominal value of input voltage, due to space limitations ,the above list is only for some products, If other than a list of products, please contact the Company’s sales department. |
封装尺寸图 Mechanical Data |
封装尺寸 Mechanical Data |
封装代号 |
L x W x H |
A1 |
25.40 × 25.40 × 10.16mm |
1.00 × 1.00 × 0.40inch |
*注意:电源模块的各管脚定义如与选型手册不符,应以实物标签上的标注为准。 *Note:The power modules such as the definition of the pin does not match with the hand book, please refer to the actual item. |
电源模块的十一个安装与维护注意事项
爱浦电子携带DC-DC模块电源-全新升级产品盛装出席“2013年高交会”
爱浦将参加香港国际电子组件及生产技术展
定压非稳压DC-DC电源模块的常见问题
爱浦模块电源在通信行业的优势及应用情况
