东电化兰达 RKE系列单体式电源
2016/6/13 15:56:22
东电化兰达 RKE系列单体式电源
产品分类:工业电源 开关电源
品牌:东电化兰达
RKE-SERIES
1200~1536W
Features
Ultra-compact high-capacity front-end power supply
Complying with the semiconductor-process device voltage sug immunity specifications in the SEMI regulations
Equipped with broad-range output voltage adjusting function (36V type: 6.0-55.0V)
Approved by safety standards (UL, C-UL, TUV), complying with Electrical Appliance and Material Safety Law, CE marking applicable
Specifications(catalog download)
Model | RKE24-50R | RKE36-42R | RKE48-32R |
Nominal Output Voltage | 24V | 36V | 48V |
Output Voltage Range | 16.8~31.2V | 25.2~55.0V | 33.6~55.0V |
Nominal Output current | 50A | 42A | 32A |
Maximum output wattage | 1200W | 1512W | 1536W |
Input Voltage Range | AC85 ~ 265V | AC85 ~ 265V | AC85 ~ 265V |
Efficiency | 81/86%(100VAC/200VAC) | 81/86%(100VAC/200VAC) | 83/88%(100VAC/200VAC) |
Operating Temperature | -10 ~+65�C | ||
EMI | EN61000-3-2 meet | ||
Function | Over current protection, Over voltage protection, Over temperature protection, Remote on/off control, Parallel operation, Variable output voltage, Monitoring signal | ||
Size (W�H�D) | 120 � 92 � 237mm |
吉方工控携手英特尔共谱智能制造“交响乐”,高性能工控机赋能行业创新
克洛托光电产业研发及产业化项目建设有新进展
鸿蒙赋能 智创未来!国内燃气行业首个燃鸿系列产品重磅发布
新大陆自动识别精彩亮相2024华南国际工业博览会
