康拓科技 粉尘防爆型远程IO数字量模块
2014/6/13 14:11:20
我们的 RemoteEX I/O 安全防爆产品可提供安全系统的传统分布式 I/O 的所有优点。它们可减少接线成本以及机器和元件的启动时间。允许您通过单一或冗余光纤或通讯电缆将 I/O 分布在危险区域各处,几乎消除了单独的本安隔栅器和隔离器、防护罩、长接线运行以及电缆槽。RemoteEX I/O 通过 Profibus DP或Modbus RTU网络与您的控制系统进行通信。
产品分类:现场总线 分布式I/O
品牌:康拓科技
产品技术规格:
型号 | 供电电压 | 输入点数 | 输入类型 | 输出点数 | 输出类型 | 总线协议 | 防护等级 |
数字量输入模块 | |||||||
CTE3-IB8-01 | DC24V | 8 | 24V输入 | — | — | Modbus RTU | IP65 |
CTE3-IB16-01 | DC24V | 16 | — | — | Modbus RTU | IP65 | |
CTE3-IB8-11 | AC220V | 8 | — | — | Modbus RTU | IP65 | |
CTE3-IB16-11 | AC220V | 16 | — | — | Modbus RTU | IP65 | |
CTE3-IB8-02 | DC24V | 8 | — | — | Profibus-DP | IP65 | |
CTE3-IB16-02 | DC24V | 16 | — | — | Profibus-DP | IP65 | |
CTE3-IB8-12 | AC220V | 8 | — | — | Profibus-DP | IP65 | |
CTE3-IB16-12 | AC220V | 16 | — | — | Profibus-DP | IP65 | |
数字量输出模块 | |||||||
CTE3-OB8-01 | DC24V | — | — | 8 | 24V输出 | Modbus RTU | IP65 |
CTE3-OB16-01 | DC24V | — | — | 16 | Modbus RTU | IP65 | |
CTE3-OB8-11 | AC220V | — | — | 8 | Modbus RTU | IP65 | |
CTE3-OB16-11 | AC220V | — | — | 16 | Modbus RTU | IP65 | |
CTE3-OB8-02 | DC24V | — | — | 8 | Profibus-DP | IP65 | |
CTE3-OB16-02 | DC24V | — | — | 16 | Profibus-DP | IP65 | |
CTE3-OB8-12 | AC220V | — | — | 8 | Profibus-DP | IP65 | |
CTE3-OB16-12 | AC220V | — | — | 16 | Profibus-DP | IP65 | |
继电器输出模块 | |||||||
CTE3-OW8-01 | DC24V | — | — | 8 | 继电器 输出 250VAC 5A | Modbus RTU | IP65 |
CTE3-OW16-01 | DC24V | — | — | 16 | Modbus RTU | IP65 | |
CTE3-OW8-11 | AC220V | — | — | 8 | Modbus RTU | IP65 | |
CTE3-OW16-11 | AC220V | — | — | 16 | Modbus RTU | IP65 | |
CTE3-OW8-02 | DC24V | — | — | 8 | Profibus-DP | IP65 | |
CTE3-OW16-02 | DC24V | — | — | 16 | Profibus-DP | IP65 | |
CTE3-OW8-12 | AC220V | — | — | 8 | Profibus-DP | IP65 | |
CTE3-OW16-12 | AC220V | — | — | 16 | Profibus-DP | IP65 | |
数字量输入输出模块 | |||||||
CTE3-IB8OW8-01 | DC24V | 8 | — | 8 | 继电器 输出 250VAC 5A | Modbus RTU | IP65 |
CTE3-IB16OW8-01 | DC24V | 16 | — | 8 | Modbus RTU | IP65 | |
CTE3-IB8OW8-11 | AC220V | 8 | — | 8 | Modbus RTU | IP65 | |
CTE3-IB16OW8-11 | AC220V | 16 | — | 8 | Modbus RTU | IP65 | |
CTE3-IB16OW16-01 | DC24V | 16 | — | 16 | Modbus RTU | IP65 | |
CTE3-IB16OW16-11 | AC220V | 16 | — | 16 | Modbus RTU | IP65 | |
CTE3-IB8OW8-02 | DC24V | 8 | — | 8 | Profibus-DP | IP65 | |
CTE3-IB16OW8-02 | DC24V | 16 | — | 8 | Profibus-DP | IP65 | |
CTE3-IB8OW8-12 | AC220V | 8 | — | 8 | Profibus-DP | IP65 | |
CTE3-IB16OW8-12 | AC220V | 16 | — | 8 | Profibus-DP | IP65 | |
CTE3-IB16OW16-02 | DC24V | 16 | — | 16 | Profibus-DP | IP65 | |
CTE3-IB16OW16-12 | AC220V | 16 | — | 16 | Profibus-DP | IP65 |
产品特点:
� 无需防爆柜即可安装到危险区域(1 区,2区)中
� 支持丰富的数字量输入输出组合
� 双总线冗余设计,提高系统稳定性
� 防护等级为IP65,具有防水防尘特性
� 适用于各种恶劣、复杂环境,工作温度在零下40至零上80摄氏度
� I/O模块与电源和通讯模块为一体化设计,保证系统可靠、稳定运行
� 具有掉线报警功能,可精确定位到坏站的位置
� 适用多种常见总线系统,如Profibus DP、Modbus RTU
� IO端子连接,便于接线
� 交流直流供电可选
� 内置过压过流保护
� 总线采用防雷、防过压、防反接保护
� 体积小巧,安装灵活
拉绳开关说明书24VDC-带应用图
拉绳开关说明书220VAC-带应用图
跑偏开关说明书24VDC-带应用图
跑偏开关说明书220VAC-带应用图
康拓科技拉绳开关说明书220VAC
