产品选型
捷迈 LS-3 系列特殊液位传感器
捷迈 LS-3 系列特殊液位传感器
Slosh ShieldBottle LevelLow Leve
产品分类:
物联网 仪器仪表 感知层 现场仪表 物位/液位仪表 物液位传感器 液位计 液位开关
品牌:
GEMS 捷迈
The durable construction of these reed switch designs ensures long, trouble-free service. Because the effects of shock, wear and vibration are minimized, these hermetically sealed switches provide precise repeatability with no more than 1% deviation. The switch actuation points remain constant over the life of the unit.
Gems™ level switches operate on a direct, simple principle. In most models, a float encircling a stationary stem is equipped with powerful, permanent magnets. As the float rises or lowers with liquid level, the magnetic field generated from within the float actuates a hermetically sealed, magnetic reed switch mounted within the stem. The stem is made of non-magnetic metals or rugged, engineered plastics.
P/N 142545 - with Slosh Shield: Compact, all-polypropylene switch with slosh shield is ideal for use with turbulent liquids in small tanks. FDA approved materials.
P/N 46999 - Bottle Level: For external mounting on tanks too small to accommodate internally mounted switches. (See note below)
P/N 76707 - For Low Level: For detecting levels as low as 5/8" (16 mm) from tank bottom. Use in water, gasoline, some oils and chemicals.
Setra西特 Model SRHM 嵌入式温湿度变送器
HENGSTLER亨士乐超薄绝对值电机反馈编码器 HRA
Hengstler亨士乐 重载防爆光电增量编码器-ISD25
Hengstler亨士乐 工业防爆增量 RX70TI/RX71TI 编码器
Hengstler亨士乐 防爆光电绝对值编码器 AX70/AX71-SSI
