产品选型
茂仁電機MN-5100封閉式限位開關
茂仁電機MN-5100封閉式限位開關
2015/9/22 9:40:41
茂仁電機MN-5100封閉式限位開關 ◆功能 1. 侧边固定式. 2. 接点敏捷. 3. 具各种不同的头及连杆. 4. 密闭式连杆 5. 辅助式密封结构. 6. 塑料成型固定座 7. 适用温度.
产品分类:
离散传感器 物联网 感知层 接近开关 位置检测
品牌:
茂仁电机
小型橫式限制開關  (Made in Taiwan)
功能 :
側邊固定式
接點敏捷
具各種不同之頭及連桿
密閉式連桿
輔助式密封結構
塑膠成型固定座
適用溫度 : +5 to +175 (-15 to +80).
額定電壓 :
10A
250V AC
0.5A
125 V AC
電氣迴路 :
特性 :
Operating speed
0.01mm to 50cm/sec(at pin plunger)
Operating frequency
120 operations/min.
Contact resistance
25m max.(intial)
Insulation resistance
100M min.(at 500 VDC)
Dielectric strength
1,000 VAC, 50/60 Hz for 1 minute between non-continuous terminals
2000 VAC, 50/60 Hz for 1 minute between current-carrying and non-current carrying parts and between each terminal and ground.
Vibration
Malfunction durability:10 to 55Hz 1.5mm double amplitude
Shock
Mechanical durability:
1,000m/sec2 (approx. 100G's)
Malfuncation durability:300m/sec2 (approx.30 G's)
Ambient operationg temperature
Operating: -10 to + 80
Humidity
95% RH max (at +20 to +35)
Service life
Mechanically:
10,000,000 operations min.(at rated OT value)
Electrically:(2A, 110VAC)MAX
500,000 operations min.
Degree of protection
IEC:IP65
Call
Call from mobile
Send SMS
Add to Skype
You'll need Skype Credit
台湾茂仁MOUJEN钥匙开关M6K-B30S2-D
台弯茂仁MOUJEN钥匙开关M6K-B30S2-A
台湾茂仁M6K-B252S1-B钥匙开关
台湾茂仁M6K-B20S2-A钥匙开关
供应台湾茂仁MOUJEN按钮开关M6K-A20S1-C
