CPU | 1. Intel® Celeron® J1800, Dual-Core, 1M Cache, 2GHz (2.41GHz), 10W(AMB-BT18S1) 2. Intel® Celeron® J1900, Quad-Core, 2M Cache, 2GHz (2.41GHz), 10W(AMB-BT19S1) 3. Intel® Atom™ E3815, Single-Core, 512K Cache, 1.46GHz, 5W (AMB-BT15S1) 4. Intel® Atom™ E3845, Quad-Core, 2M Cache, 1.91GHz, 10W (AMB-BT45S1) | Chipset | Intel Bay Trail SoC | Memory | 1 x DDR3L-1333MHz, SO-DIMM, up to 8GB (AMB-BT19S1) | BIOS | AMI UEFI BIOS |
Graphic Controller | Intel® HD Graphics | Video Memory | Shared Memory | Video Interface | ● 2 x VGA (Resolution up to 2560 x 1600 @ 60Hz) ● 1 x LVDS (24-Bit Dual channel LVDS, Resolution up to 1920x1200 @ 60Hz) |
SATA | 1 x SATA II Port + 1 x mSATA |
Ethernet | 2 x GbE LAN(Optional) | Expansion Slot | 2 x mini PCIe | Ethernet Chip | 2 x Realtek GbE LAN Chip | Serial Port | ● COM1(DB9 connector) ● COM1~COM5 x RS232 2.0 pitch pin header ● COM6(RS232/485) | USB | ● 2 x USB 2.0 port on rear I/O ● 5 x USB 2.0 pin header | GPIO | 8 bit Digital I/O | Audio | Realtek ALC888 5.1-channel High Definition Audio 1 x Line in, 1 x Line out | Keyboard/Mouse | 1 x PS/2 Header for Key Board/Mouse | SIM | 1 x SIM slot |
Power Input | 4-Pin power connector | Power Output | 1 x System FAN 3-Pin Power connector |
OS Support | Windows 7 (32 bit/64 bit), Windows 8.1 (32 bit/64 bit), Linux (by reguest) |
Dimension | 146 mm x 105 mm (5.7" x 4") | Operating Temp. | 0~60°C | Storage Temp. | -20~75°C | Safety | RoHS |
● 1 x AMB-BT19S1 | ● 1 x Quick User Guide | ● 1 x Driver CD | ● 1 x SATA Cable |
AMB-BT18S1 | Intel Celeron J1800, Dual Core, 1M cache, 2GHz (2.41GHz), 10W (2 x LAN, 6 x COM) | AMB-BT19S1 | Intel Celeron J1900, Quad Core, 2M cache, 2GHz (2.41GHz), 10W (2 x LAN, 6 x COM) | AMB-BT15S1 | Intel Atom E3815, Single Core, 512K cache, 1.46GHz, 5W (2 x LAN, 6 x COM) | AMB-BT45S1 | Intel Atom E3845, Quad Core, 2M cache, 1.91GHz, 10W (2 x LAN, 6 x COM) |
Specifications are subject to change without notice.
