CPU | 1. Intel® Celeron® Bay Trail J1900, Quad-core, clock speed 2.0GHz 2. Intel® Celeron® Bay Trail J1800, Dual-core, clock speed 2.41GHz | Memory | 1 x DDR3L-1600MHz, SO-DIMM, up to 8GB | BIOS | AMI UEFI | WatchDog Timer | Software programmable 1~255 sec. |
Graphic Controller | Integrated graphics support for processors with Intel Graphics Technology | Video Interface | 1 x VGA (1 x internal header) |
Chipset | 6 x Intel GbE chip | Connector | 6 x RJ45 with LED | LAN bypass | Yes (one pair) |
SATA | 1 x SATAII port | CF | 1 x Compact Flash Type II socket | HDD Bay | 1 x 2.5” HDD Bay |
Expansion | 2 x mini PCIe slot | Console Port | 1 x Console (1 x RJ45) | USB | 1 x USB 3.0, 3 x USB 2.0 (2 x external) | Antenna Hole | 2 x SMA for Wi-Fi (IEEE 802.11a/b/g/n/ac) |
Power Input | 1 x DC 12V input (1 x 2.5 DC jack) |
OS Support | Windows 7 / Windows 8 / Linux |
Dimension | 234.6 x 151.4 x 43.5 mm | Operating Temp. | 0~40°C | Storage Temp. | -20~75°C | Safety | CE, FCC class A |
● 1 x AND-J190N1, 1 x AND-J180N1 (6LAN SKU) | ● 1 x AND-J190N2, 1 x AND-J180N2 (4LAN SKU) | ● 1 x Driver CD | ● 1 x Quick Guide | ● 1 x Console Cable (DB9) | ● 1 x SATA Cable | ● 1 x SATA Power Cable | ● 2 x SMA Antenna | ● 1 x Power Adaptor | ● 1 x Power Cord (Option for USA/UK/EU/JPN/AU/RSA) |
AND-J190N1 | Microbox with Intel® Celeron® Bay Trail J1900, DDR3L, 6 x GbE, USB 2.0/USB 3.0, SATA II, CF, mini PCIe | AND-J190N2 | Microbox with Intel® Celeron® Bay Trail J1900, DDR3L, 4 x GbE, USB 2.0/USB 3.0, SATA II, CF, mini PCIe | AND-J180N1 | Microbox with Intel® Celeron® Bay Trail J1800, DDR3L, 6 x GbE, USB 2.0/USB 3.0, SATA II, CF, mini PCIe | AND-J180N2 | Microbox with Intel® Celeron® Bay Trail J1800, DDR3L, 4 x GbE, USB 2.0/USB 3.0, SATA II, CF, mini PCIe |
Specifications are subject to change without notice. |
