宜鼎国际SATADOM™-SL 3IE3 V2电子硬盘
SATADOM™-SL 3IE3 V2
产品分类:工控机 嵌入式系统 其它 工控机配件 存储产品 存储产品
品牌:宜鼎国际
Features
iSLC technology
Built-in Pin 8 power supply
Best boot drive solution for server and embedded system
SATA 6Gb/s interface
High IOPS to reduce boot up timing
DRAM-less, 100% data integrity
Innovative Firmware Algorithm
Anti-vibration mechanical design
Built in iData Guard
Overview
Innodisk Serial ATA Disk on Module (SATADOM) supports SATA III standard (6.0Gb/s) interface with excellent performance, and SATADOM-SL 3IE3 V2 is designed as the smallest form factor size that could enhance compatibility with various design applications.
The innovative Pin8 uses the SATA connector itself as a power supply to drive the device without external cables. It could be connected directly to the SATA onboard socket on customers’ system without additional power cable. Besides, the booting time for operation and the power consumption is less than hard disk drive (HDD), and can work under harsh environment compile with ATA protocol, no additional drives are required, and the SSD can be configured as a boot device or data storage device.
Specifications
宜鼎全面扩充边缘AI智能应用与智能存储 Computex 2024新品齐发、全新品牌主张亮相
宜鼎推出 iCAP Air 智能物联空气质量管理解决方案
宜鼎独创MIPI over Type-C解决方案突破技术局限,改写嵌入式相机模块市场样貌
宜鼎国际亮相第89届CMEF 积极推动AI智能方案的应用
宜鼎国际2.5" SATA SSD 3TS6-P AES工业用闪存模块
