产品选型
宜鼎国际SATADOM™-ML 3SE3电子硬盘
2017/5/5 11:27:28
产品分类:
工控元器件 工控机 工控机配件 存储器 固态电子盘 存储产品
品牌:
宜鼎国际
Features
Best boot drive solution for server and embedded system
SATA III interface
High IOPS to reduce boot up timing
Built-in Pin 8 power supply
Intelligent error recovery system
Zero mechanical interference
Anti-vibration mechanical design
iSMART disk health monitoring
Overview
Innodisk Serial ATA Disk on Module (SATADOM™) supports SATA III standard (6.0Gb/s) interface with excellent performance, and SATADOM™-ML 3SE3 is designed as the smallest form factor size that could enhance compatibility with various design applications.
Innodisk’s patented Pin 7 and Pin 8 SATA power supply technologies use the SATA connector itself as a power supply to drive the devicewithout external power cables. It is a 100% cable-less, shock resistant, space saving and plug-and-play storage solution that optimizes airflow and makes the best use of limited board space in embedded and rackmount server systems.
Innodisk SATADOM™-ML 3SE3 effectively reduces the booting time of operation system andthe power consumption is less than hard disk drive (HDD), and complies with ATA protocol, no additional drives are required, and can be configured as a boot device or data storage device.
Specifications
宜鼎全面扩充边缘AI智能应用与智能存储 Computex 2024新品齐发、全新品牌主张亮相
宜鼎推出 iCAP Air 智能物联空气质量管理解决方案
宜鼎独创MIPI over Type-C解决方案突破技术局限,改写嵌入式相机模块市场样貌
宜鼎国际亮相第89届CMEF 积极推动AI智能方案的应用
宜鼎国际2.5" SATA SSD 3TS6-P AES工业用闪存模块
