鑫精诚XJC-S07-Q-10拉压力传感器
拉压力传感器XJC-S07-Q-10【鑫精诚】
产品分类:仪器仪表 压力仪表 现场仪表 压力传感器
品牌:产品介绍
特点 Feature
◆拉压力传感器XJC-S07-Q-10采用高精度电阻应变式原理
◆可满足 4.9N-196N范围内的力测量。
◆不锈钢材料,密封焊接,防油、防水、耐腐蚀
◆圆型结构设计,压式承载,安装使用方便灵活。
◆安全防爆型产品,可用于恶劣环境及危险性场合。
◆不锈钢材料
◆体积小巧,外型美观
◆动态响应频率高,高精度。
◆XJC-S07-Q-10 adopts high-precision resistance strain principle
◆Meet force measurement in the range of 4.9N-196N.
◆ Stainless steel material with sealed welding, oil, water, corrosion resistance
◆Round structural design, pressure-bearing, easy to install.
◆ Safe and explosion-proof product suitable for harsh environments and dangerous situations.
◆ Aluminum / stainless steel
◆ Small size, beautiful appearance
◆ High dynamic response frequency
技术参数(Technical parameters):
量程 Capacity | 0-(4.9N-196.0N) (500G-20KG) | 材质 Material
| 不锈钢Stainless steel | |
精度 Accuracy | 0.3% F.S. | 输出灵敏度 Rated output | 2.0mV/V | |
使用电压力 Recommended excitation | 5V | 最大使用电压 Maximum excitation | 10V | |
固有频率 Natural frequency | ≥2KHZ | 温度补偿范围 Compensated temp range | - 10 ~ 40 ºC | |
滞后 Hysteresis | 0.02% F.S. | 工作温度 范围 Operating temp range | - 20 ~ 60 ºC | |
重复性 Repeatability
| 0.02% F.S. | 绝缘电阻 Insulation
| ≥5000MΩ/100VDC | |
输入阻抗 Input impedance | 350 ± 30 Ω | 输出阻抗 Output impedance | 350 ± 10 Ω | |
蠕变 (30分钟) Creep (30min) | 0.02% F.S. | 温度灵敏度漂移 Temp effect on output | 0.02% F.S. / 10ºC | |
零点输出 Zero balance | ± 2% F.S. | 零点温度漂移 Temp effect on zero | 0.02% F.S. / 10ºC | |
安全超载 Safe load limit | 150% | 极限超载 Ultimate load limit | 200% | |
电缆线尺寸 Cable size | ∅2 x4m | 使用寿命 Life | 满量程100万次以上 Full scale more than 1 million times | |
电缆线连接方式 Cable connection | Ex + : 红 Red; Ex - : 黑 Black; Sig + : 绿 Green Sig - : 白 White |
主要应用 Applications
汽车,医疗,机器人,电子,机械设备,自动化设备等
Automotive, medical, robot, e l e c t r onic, mechanical equipment, automation equipment, etc.
例如:按键手感度测试仪,冷热压机压力检测,机器人手抓力等安装空间小的力值检测领域
Force measurement in small space installation, such as feeling tester for keyboard switch, compression force measurement for hot and cold lamination machine, and grasping force measurement for robotic hands.
鑫精诚传感器 诚邀您参观:IBTE 2020深圳电池技术展
展会进行时|鑫精诚传感器参展2020华南工博会,已在线等待!
邀请函|鑫精诚传感器欢迎您莅临上海DIC EXPO 2020展会
测力传感器的应用范围及使用环境
多维力传感器被广泛应用
