万捷 M12成型式线缆
圆形M12连接器防水,耐油,耐寒,性能稳定,高效快速连接,广泛用于 汽车传感器 连接线 光电开关,接近开关,工业自化 机器人传感器和各种工业4.0集成线束布线系统中,万捷可为客户配合提供各种不同创新型设备连接器及连接器线缆。
产品分类:电气连接 工业连接器
品牌:产品介绍
产品介绍:
产品优势
1.)电气连接可用于传输信号,数据,电源,应用各不同领域.
2.)螺纹旋扭对插连接,电气性能稳定,可用于持续冲击,振动等应用环境.
3.)密封性能佳,防护等级可达IP67,IP68或IP69K
4.)屏蔽性可选:非屏蔽,屏蔽,接地.
5.)适用于各种场合的连接技术.
6.)不同编码连接器,带有防呆,防止插错特点.
7.)可与市场同行同系列连接器互配对插.
8.)产品符合IEC61076,产品种类多,可自行选择应用.
Product advantages
1)Electrical connection can be used to transmit Signal, Data, Power supply and
Application in different fields
2) Screw Twist butt joint, Stable electrical performance, Can be used in continuous impact, Vibration and other applications
3.) Good sealing performance, Protection grade up to IP67, IP68 or IP69K
4.)Shielding optional: non shielding, shielding, Grounding
5) Connection technology applicable to various occasions
6) Different coding connectors are provided with anti dazzle and anti wrong insertion features
7.) It can be matched and inserted with the same series of connectors of the same industry in the market
8) There are many kinds of products conforming to IEC61076, Which can be applied by yourself
万捷M12圆形连接器
万捷M8,M5圆形连接器
万捷 M12面板式全屏蔽
万捷 M12面板式焊线式
万捷 M12面板式焊接式
