- 型号:SZF0-0,4X2,5
- 数量:100
- 制造商:菲尼克斯
- 有效期:2056/7/31 0:00:00
1204504 SZF0-0,4X2,5 SZF 0-0,4X2,5
1204520 SZF2-0,8X4,0 SZF 2-0,8X4,0
1205037 SZS0,4X2,5 SZS 0,4X2,5
1205066 SZS1,0X4,0 SZS 1,0X4,0
5772168 VAL-MS320 VAL-MS 320
0311236 SB2-RTK/S SB 2-RTK/S
3025529 D-MT1,5BU D-MT 1,5 BU
1413036 MBK3/E-Z MBK 3/E-Z
1413117 MBK3/E-Z-PE MBK 3/E-Z-PE
3003363 MT1,5BU MT 1,5 BU
2810612 MACXMCR-SL-CAC-5-I MACX MCR-SL-CAC-5-I
2859181 VAL-MS320/3+1/FM VAL-MS 320/3+1/FM
3200072 AI2,5-18GY AI 2,5 -18 GY
1205451 CRIMPFOXUD10-4 CRIMPFOX UD 10-4
1805615 KGS-MSTB2,5/20 KGS-MSTB 2,5/20
2858577 VAL-MS320/3+1-FM VAL-MS 320 /3+1-FM
2941154 DEK-REL-24/O/1 DEK-REL- 24/O/1
3011067 VIOK1,5-D/TG/D/PE VIOK 1,5-D/TG/D/PE
0921011 ST-SI-UK4 ST-SI-UK 4
1766990 GMSTB2,5/2-ST-7,62 GMSTB 2,5/ 2-ST-7,62
1604796 HC-B16-TFL-60/O1M25S HC-B 16-TFL-60/O1M25S
2744416 PSM-ME-RS232/RS485-P PSM-ME-RS232/RS485-P
1881354 FK-MC0,5/5-ST-2,5 FK-MC 0,5/ 5-ST-2,5
1881464 MC0,5/4-G-2,5 MC 0,5/ 4-G-2,5
1881477 MC0,5/5-G-2,5 MC 0,5/ 5-G-2,5
1881341 FK-MC0,5/4-ST-2,5 FK-MC 0,5/ 4-ST-2,5
2869728 ME6,2TBUS-21,5/5-ST-3,81GN ME 6,2 TBUS-2 1,5/5-ST-3,81 GN
5774768 E/UKCN E/UK CN
2826198 ST-REL4-KG230/1-1/AU ST-REL4-KG230/1-1/AU
5100219 UM72-R-230UC/21-21 UM 72-R-230 UC/21-21
2966595 OPT-24DC/24DC/2 OPT-24DC/24DC/2
2708083 PSI-MOS-DNETCAN/FO850/BM PSI-MOS-DNET CAN/FO 850/BM
2744788 FLMC10BASE-T/FOG850 FL MC 10BASE-T/FO G850
2963941 PSR-SPP-24UC/ESA4/3X1/1X2/B PSR-SPP- 24UC/ESA4/3X1/1X2/B
1507777 SACC-M12FSB-5CON-PG9SHAU SACC-M12FSB-5CON-PG9 SH AU
1681088 SACC-M12MS-4CON-PG 7 SACC-M12MS-4CON-PG 7
3040397 SP2,5/15 SP 2,5/15
1786226 IC2,5/7-ST-5,08 IC 2,5/ 7-ST-5,08
3200195 AI1,5-10BK AI 1,5 -10 BK
3200205 AI2,5-12GY AI 2,5 -12 GY
2708274 PSI-MOS-PROFIB/FO 850E PSI-MOS-PROFIB/FO 850 E
2708261 PSI-MOS-PROFIB/FO 850T PSI-MOS-PROFIB/FO 850 T
2839347 PT2-PE/S-230AC-ST PT 2-PE/S-230AC-ST
2905064 ST-OV2-220DC/ 60DC/1 ST-OV2-220DC/ 60DC/1
2823625 ST-REL2-KG24/1 ST-REL2-KG 24/1
3200522 AI 2,5- 8BU AI 2,5 - 8 BU
2295554 PLC-V8/FLK14/OUT PLC-V8/FLK14/OUT
2296553 PLC-V8/FLK14/IN PLC-V8/FLK14/IN
3022276 CLIPFIX35-5 CLIPFIX 35-5
2980377 PLC-BSP-230UC/21/SO46 PLC-BSP-230UC/21/SO46
2954947 EMG45-SI8E EMG 45-SI8E
2810984 MCR-C-U-I-10B-0B-DCI MCR-C-U-I-10B-0B-DCI
3040274 SP2,5/ 3 SP 2,5/ 3
2952185 EMG45-REL/IR-W230/HWR EMG 45-REL/IR-W230/HWR
2775184 UDK4-PE UDK 4-PE
2858506 POWERSETBC/3/FM/PLUS POWERSET BC/3/FM/PLUS
5774564 UM72-R-24DC/4*21 UM72-R-24DC/4*21
2771007 UKKB10/2,5 UKKB 10/2,5
2940430 EMG17-REL/KSR-W230/21-21-LC EMG 17-REL/KSR-W230/21-21-LC
2810625 MACX MCR-SL-CAC-5-I-UP MACX MCR-SL-CAC-5-I-UP
2943259 EMG 17-OV-TTL/ 24DC/2 EMG 17-OV-TTL/ 24DC/2
2938976 QUINT-PS-100-240AC/48DC/20 QUINT-PS-100-240AC/48DC/20
1663129 SACC-M12MR-5CON-PG 7-M SACC-M12MR-5CON-PG 7-M
2950734 EMG 45-RELS/K2-G220 EMG 45-RELS/K2-G220
2960106 REL-SG220/B110 REL-SG220/B110
1004348 KLM-A KLM-A
2950501 EMG 22-RELS/K1-W230 EMG 22-RELS/K1-W230
2950666 EMG 45-RELS/K2 EMG 45-RELS/K2
2950967 EMG 45-RELS/IR1 EMG 45-RELS/IR1
- 电话:021-66100983 66100663
- 传真:021-61638399-9148
- email:boyi1010@126.com
