扭矩遥测系统-TT9000
2008/7/22 9:09:31
0 人气:50
- 型号:TT9000
- 数量:10000
- 制造商:嘉兆科技(深圳)有限公司
- 有效期:2018/7/31 0:00:00
产品应用:
The TorqueTrak 9000 Digital Radio Telemetry System converts virtually any drive shaft into a rotating torque sensor. The miniature battery-powered transmitter rides on the shaft and broadcasts digital data from a torque-sensitive strain gage. Simple and easy to install the microprocessor-based system provides accurate and reliable torque data in real time during actual machine operation.
产品特点:
Easy to Install Fits any size shaft. No machine modifications or disassembly required.
Easy to Use Wire up strain sensor and start transmitting torque data. Calibration is done off-the-shaft.
Digital Data Transmission Delivers a clean, noise-free data signal.
Eight Channels Use multiple systems simultaneously without signal interference or crosstalk.
Seven Gain Levels Amplify the strain/torque signal to the most useful level.
AutoZero Toggle Switch Cancels out any null offset voltage and automatically sets the Zero reference.
证书:CE
更多产品请登录:http://www.corad.com.cn/
- 电话:0755-83760007
- 传真:0755-83761816
- email:Enquiry@tnm-corad.com.cn
工控宝APP下载安装
