- 型号:AC0116 Manual AS-Interface English
- 数量:125
- 制造商:IFM
- 有效期:2026/10/31 0:00:00
IFM接近开关/中国托菲机电
易福门是一家三十多年来在全球范围内一直从事研究、生产及销售用于信号的检测、控制及处理的元器件和系统的跨国集团企业 -从标准的传感器到特定应用的控制器.主要产品集中于接近传感器,光电传感器, 控制系统,识别系统,附件,流量传感器,压力传感器和电流传感器,温度传咸器,总线系统
98454 EMS-Base FC Adressierst. P+F
98455 EEMS-Base FC Adressierst. P+F
99334 EMS-Base FC P+F
99335 EEMS-Base FC P&F
AC0005 Profikit DEUTSCH
AC0006 Profikit ENGLISH
AC0007 Added Value package AS-i T5
AC0017 Added Value package AS-i T5
AC0019 Added Value package AS-i T5
AC001S Safety monitor/1 channel
AC0020 Added Value package AS-i T5
AC0021 Added Value package AS-i T5
AC0022 Added Value package AS-i T5
AC0023 Added Value package AS-i T5
AC0024 Added Value package AS-i T5
AC002S Safety monitor/2 channel
AC003S Safety monitor/1 ch. enhan.
AC004S Safety monitor/2 ch. enhan.
AC005A ClassicLine 4DI T M12 Atex
AC005S ClassicL45 1DI/2DI M12
AC006S ClassicL90 2SI 2DO T M12
AC007A ClassicL45 2DI 2DO T M12
AC007S BWS-Modul
AC008A ClassicL45 4DO T M12 ATEX
AC009A ClassicLine 4DI 4DO T M12 Atex
AC009S SmartLine SafetyModul
AC010S E-stop illuminated IP67
AC0115 Manual AS-Interface German
AC011S E-stop key switch IP67
AC014A ClassicL45 2DO-y 2DI-y T M12
AC015S AS-i Safety pcb 2-SI/1-DO
AC016S CL90,Evaluation unit,AS-i
AC0305 System-Software + Handbuch Deu
AC0306 System-Software + Handbuch Eng
AC0307 System-Software + Handbuch Fra
AC0311 System-Software + Handbuch Deu
AC0312 System-Software + Handbuch Eng
AC0314 Controller-Library German
AC0315 System-Software + Handbuch Deu
AC0317 System-Software + Handbuch Deu
AC0325 Controller-Library English
AC0326 Softw.for ControllerE full Ger
AC0327 Softw.for ControllerE full Eng
AC0340 CoDeSys 2.3 CD full f. Cont
AC0346 Manual CoDeSys 2.3 German
AC0347 Manual CoDeSys 2.3 English
AC042A AirBox 2DI 1PO M12 II 3D
AC046A AirBox 2DI 1PO M12 ATEX
AC1004 CONTR 2MSTR 1RS232C
AC1005 Contr 1MSTR 1RS232C 1DP
AC1006 Contr 2MSTR 1RS232C 1DP
AC1008 CONTR/1MSTR/1RS232C/1DN
AC1011 Contr 1MSTR 1RS232C 1RS485
AC1012 Contr 2MSTR 1RS232C 1RS485
AC1015 Repeater 6GK1 210-0SA00 IP67
AC1016 Extender 6GK1 210-1SA00 IP67
AC1018 Controller 1MSTR 1RS232C 1DP
AC1020 Contr 2MSTR 1RS232C 1IBS
AC1023 Contr 1MSTR 1RS232C 1RS232C
AC1053 .masterSteckkarte CP2430 für
AC1057 .masterS7-300 CP343-2 6GK7 343
AC1060 ASI M-MODUL
AC1092 Modbus Gateway RS485 B+W 1037
AC1093 Modbus Plus Gateway V2.1
AC1095 PCB PCI-Card 2 Master
- 电话:021-55310107
- 传真:021-65311031
- email:li_13817626600@126.com
评价: |
一般 | |
