- 型号:140CPU43412UC
- 数量:1000
- 制造商:施耐德
- 有效期:2020/11/18 0:00:00
施耐德昆腾140PLC产品型号说明:
140CPU11302 Quantum CPU 256K SRAM, 8K LL984,109K IEC,10K 寄存器,1MB&1MB+ 21,818
140CPU
140CPU11303 Quantum CPU 512K SRAM, 16K LL984,368K IEC,10K 寄存器,1MB&1MB+ 39,552
140CPU
140CPU31110 Quantum Unity CPU 486处理器,66MHz,
140CPU
140CPU
140CPU
140CPU43412U Quantum Unity CPU 486 处理器,66MHz,
140CPU43412UC Quantum Unity CPU 486 处理器,66MHz,
140CPU53414B Quantum CPU 586,
140CPU53414BC Quantum Unity CPU 586 处理器,133MHz,
140CPU65150 Quantum Unity CPU 166MHz,
140CPU65160 Quantum Unity CPU 266MHz,
140CPU67160 Quantum Unity HSBY CPU 67160 ,热备冗余CPU 99,133
140CPU65260 Quantum Unity CPU 266MHz,
140CPU
140CPU
140CPU
140CPU
Quantum Hot Standby 双机热备
140CHS11000 Quantum QUANTUM 热备模块 51,582
140CHS
140CHS21000 Quantum QUANTUM 热备套件 97,431
140CHS
140CHS32000 Quantum QUANTUM 热备远程I/O同轴电缆终结套件 5,835
140CHS41010 Quantum Level One 低成本热备套件 129,936
140CHS41020 Quantum Level One 低成本热备套件 157,764
140SHS94500 Quantum 热备功能可装载软件 4,410
990XCA65609 Quantum 热备模块光纤电缆 1,148
490NOR00003 Quantum Ethernet MTRJ- MTRJ 光纤电缆,
490NOR00005 Quantum Ethernet MTRJ- MTRJ 光纤电缆,
490NOR00015 Quantum Ethernet MTRJ- MTRJ 光纤电缆,
Quantum Memory 内存卡
TSXMCPC
TSXMCPC224K Quantum Unity V2 PCMCIA存储扩展卡,程序存储224K(Flash),数据存储256K(RAM) 3,583
TSXMCPC512K Quantum Unity V2 PCMCIA存储扩展卡,程序存储512K(Flash),数据存储512K(RAM) 6,790
TSXMFPB096K Quantum Unity V2 PCMCIA程序备份卡,程序存储96KB(Flash) 2,376
TSXMFPP
TSXMFPP
TSXMFPP
TSXMFPP128K Quantum Unity V2 PCMCIA存储扩展卡,程序存储128K(Flash) 1,886
TSXMFPP224K Quantum Unity V2 PCMCIA存储扩展卡,程序存储224K(Flash) 3,536
TSXMFPP384K Quantum Unity V2 PCMCIA存储扩展卡,程序存储384K(Flash) 4,409
TSXMFPP512K Quantum Unity V2 PCMCIA存储扩展卡,程序存储512K(Flash) 5,847
TSXMRPC
TSXMRPC001MC Quantum Unity V2 PCMCIA存储扩展卡(SRAM),程序存储192-1024K,数据存储832-0K,带涂敷涂层 6,931
TSXMRPC
TSXMRPC
TSXMRPC003MC Quantum Unity V2 PCMCIA存储扩展卡(SRAM),程序存储192-3072K,数据存储2880-0K,带涂敷涂层 12,259
TSXMRPC
TSXMRPC007MC Quantum Unity V2 PCMCIA存储扩展卡(SRAM),程序存储192-7168K,数据存储6976-0K,带涂敷涂层 18,389
TSXMRPC
TSXMRPC448K Quantum Unity V2 PCMCIA存储扩展卡(SRAM),程序存储192-448K,数据存储256-0K 3,583
TSXMRPC768K Quantum Unity V2 PCMCIA存储扩展卡(SRAM),程序存储192-768K,数据存储576-0K 4,715
TSXMRPF
TSXMRPF
TSXMRPP128K Quantum Unity V2 PCMCIA存储扩展卡(SRAM),程序存储128K,数据存储0K 2,904
TSXMRPP224K Quantum Unity V2 PCMCIA存储扩展卡(SRAM),程序存储224K,数据存储0K 3,807
TSXMRPP384K Quantum Unity V2 PCMCIA存储扩展卡(SRAM),程序存储384K,数据存储0K 4,999
Quantum Power Supply 电源模板
140CPS11100 Quantum 电源 115/230 VAC,独立
140CPS
140CPS11420 Quantum Quantum 电源,115/230 VAC,可累加,11Amp 7,634
140CPS
140CPS12420 Quantum Quantum 电源,115/230 VAC,冗余,11Amp 9,171
140CPS
140CPS21100 Quantum Quantum电源 24 VDC,独立
140CPS
140CPS21400 Quantum Quantum电源,24 VDC,可累加,
140CPS
140CPS22400 Quantum Quantum 电源,24 VDC,冗余,8Amp 10,220
140CPS
140CPS41400 Quantum Quantum 电源,48-60 VDC,可累加,8Amp 11,356
140CPS
140CPS42400 Quantum Quantum 电源,48-60 VDC,冗余,8Amp 13,627
140CPS
140CPS51100 Quantum Quantum电源 125 VDC,独立
140CPS
140CPS52400 Quantum Quantum 电源,125 VDC,冗余,8Amp 10,220
140CPS
Quantum Digital Input Module 开关量输入模板
140DAI34000 Quantum 开关量 AC 输入,16 点,24 VAC,隔离 5,268
140DAI
140DAI35300 Quantum 开关量 AC 输入,32 点,24 VAC, 8 点成组隔离 7,608
140DAI
140DAI44000 Quantum 开关量 AC 输入,16 点,48 VAC,隔离 5,263
140DAI
140DAI45300 Quantum 开关量 AC 输入,32 点,48 VAC, 8 点成组隔离 7,608
140DAI
140DAI54000 Quantum 开关量 AC 输入,16 点,115 VAC,隔离 4,983
140DAI
140DAI54300 Quantum 开关量 AC 输入,16 点,115 VAC, 8 点成组隔离 4,325
140DAI
140DAI55300 Quantum 开关量 AC 输入,32 点,115 VAC, 8 点成组隔离 7,323
140DAI
140DAI74000 Quantum 开关量 AC 输入,16 点,230 VAC,隔离 4,983
140DAI
140DAI75300 Quantum 开关量 AC 输入,32 点,230 VAC, 8 点成组隔离 7,175
140DAI
140DDI15310 Quantum 开关量 DC 输入,32 点,5 VDC, 4 组隔离,负逻辑 6,143
140DDI
140DDI35300 Quantum 开关量 DC 输入,32 点,24 VDC, 4 组隔离 5,906
140DDI
140DDI35310 Quantum 开关量 DC 输入,32 点,24 VDC, 4 组隔离,负逻辑 6,144
140DDI
140DDI36400 Quantum 开关量 DC 输入,96 点,24 VDC, 6 组隔离 10,537
140DDI
140DDI67300 Quantum 开关量 DC 输入,24 点,125 VDC, 3 组隔离 6,438
140DDI
140DDI84100 Quantum 开关量 DC 输入,16 点,10-60 VDC, 8 组隔离 5,319
140DDI
140DDI85300 Quantum 开关量 DC 输入,32 点,10-60 VDC, 4 组隔离 7,085
140DDI
140DII33000 Quantum 开关量输入 8 通道, 本安型, 15,897
140DII
140DSI35300 Quantum 开关量 Supervised DC 输入,32 点,24 VDC, 4 组隔离(断线检测) 8,523
140DSI
Quantum Digital Output Module 开关量输出模板
140DAO84000 Quantum 开关量 AC 输出,16 点,24-230 VAC,隔离,
140DAO
140DAO84010 Quantum 开关量 AC 输出,16 点,24-115 VAC,隔离,
140DAO
140DAO84210 Quantum 开关量 AC 输出,16 点,110-230 VAC,隔离,4 组隔离,
140DAO
140DAO84220 Quantum 开关量 AC 输出,16 点,24-48 VAC,隔离,4 组隔离,
140DAO
140DAO85300 Quantum 开关量 AC 输出,32 点,24-230 VAC, 4 组隔离,
140DAO
140DDO15310 Quantum 开关量 DC 输出,32 点,5 VDC TTL, 4 组隔离, 75mA/点 7,303
140DDO
140DDO35300 Quantum 开关量 DC 输出,32 点,24 VDC, 4 组隔离,
140DDO
140DDO35301 Quantum 开关量 DC 输出,32 点,24 VDC, 4 组隔离,
140DDO
140DDO35310 Quantum 开关量 DC 输出,32 点,24 VDC, 4 组隔离,
140DDO
140DDO36400 Quantum 开关量 DC 输出,96 点,24 VDC, 6 组隔离,
140DDO84300 Quantum 开关量 DC 输出,16 点,10-60 VDC, 2 组隔离,
140DDO
140DDO88500 Quantum 开关量 DC 输出, 12 点, 24-125 VDC, 2 组隔离,
140DDO
140DIO33000 Quantum 开关量输出 8 通道, 本安型 20,448
140DIO
140DRA84000 Quantum 继电器输出,16 点,NO,
140DRA
140DRC83000 Quantum 继电器输出,8 点,NO/NC,
140DRC
140DVO85300 Quantum 开关量Verified DC 输出,32 点,10-30 VDC, 4 组隔离,
140DVO
Quantum Digital Mixed Module 开关量混合模板
140DAM59000 Quantum 开关量 DC 混合模块,16 点输入,125 VAC, 8点输出 5,607
140DAM
140DDM39000 Quantum 开关量 DC 混合模块,16 点输入,24 VDC, 8 点输出 5,365
140DDM
140DDM69000 Quantum 开关量 DC 混合模块,4 点输入,125 VDC, 4 点输出 6,788
140DDM
Quantum Analog Input Module 模拟量输入模板
140ACI03000 Quantum 模拟量输入,单极性,8 通道,4-20mA 或 1-5VDC,12位 11,021
140ACI
140ACI04000 Quantum 模拟量输入,16 通道,4-20mA,0-20mA,0-25mA,12或14位 17,661
140ACI
140AII33000 Quantum RTD/TC 输入, 8通道, 本安型 34,188
140AII
140AII33010 Quantum 模拟量输入, 8通道, 电流, 本安型 具体价格请联系HEC
140AII
140ARI03010 Quantum RTD 输入,8 通道,类型 NI 或 PT, 100, 200, 500, 1000 15,428
140ARI
140ATI03000 Quantum TC 输入,8 通道,类型 J, K, E, T, S, R, B 15,428
140ATI
140AVI03000 Quantum 模拟量输入,8 通道,双极性,多量程 13,225
140AVI
Quantum Analog Output Module 模拟量输出模板
140ACO02000 Quantum 模拟量输出,4 通道,4-20mA,通道隔离,12位 11,021
140ACO
140ACO13000 Quantum 模拟量输出,8 通道,高密度 16,577
140ACO
140AIO33000 Quantum 模拟量输出, 8 通道, 15-位,本安型 28,885
140AIO
140AVO02000 Quantum 模拟量输出,4 通道,电压 11,021
140AVO
Quantum Analog Mixed Module 模拟量混合模板
140AMM09000 Quantum 模拟量混合模块,4 通道输入,2 通道输出 10,474
140AMM
Quantum Intelligent Module 智能模板
140EHC20200 Quantum 高速计数模块,24 VDC, 500KHz, 2 通道 13,627
140EHC10500 Quantum 高速计数模块,100kHz@5 VDC, 35kHz@24VDC,5 通道 13,627
140EHC
140EHC
140HLI34000 Quantum 高速锁存/计数模块,24 VDC 6,250
140HLI
140ERT85410 Quantum 事件纪录模块,SER 15,326
Quantum Backplane 背板
140XBP00200 Quantum 背板,2 槽 1,158
140XBP
140XBP00300 Quantum 背板,3 槽 2,112
140XBP
140XBP00400 Quantum 背板,4 槽 2,118
140XBP
140XBP00600 Quantum 背板,6 槽 2,608
140XBP
140XBP01000 Quantum 背板,10 槽 3,766
140XBP
140XBP01600 Quantum 背板,16 槽 4,924
140XBP
140XBE10000 Quantum 背板扩展模块 3,437
140XBE
140XCA71703 Quantum 背板扩展电缆,
140XCA71706 Quantum 背板扩展电缆,
140XCA71709 Quantum 背板扩展电缆,
Quantum Remote I/O (S908-Coax.) 远程I/O系统
140CRP93100 Quantum RIO 处理器接口,S908 Head,单电缆 11,466
140CRP93200 Quantum RIO 处理器接口,S908 Head,双电缆 16,052
140CRA93100 Quantum RIO 站适配器,S908 RIO,单电缆 11,466
140CRA93200 Quantum RIO 站适配器,S908 RIO,双电缆 16,052
140CRA
140CRA93101 Quantum LMS RIO 站适配器, S908 RIO, 单电缆 12,603
140CRA
140CRA
140CRP
140CRP
490NRP95400 Quantum RIO 光纤中继器 23,675
975750000 Quantum RIO同轴电缆,RG-6 8,078
975951000 Quantum RIO同轴电缆,RG-11 15,661
ASMBII003 Quantum RIO预装分站电缆
ASMBII004 Quantum RIO预装分站电缆
MA0185100 Quantum 远程I/O电缆 分支器 1,807
MA0186100 Quantum 远程I/O电缆 分离器 1,807
MA0331000 Quantum REMOTE I/O TRUNK SPLITTER 1,897
520402000 Quantum 远程I/O分支器终端电阻 27
520422000 Quantum 远程I/O干电缆终结电阻,75 欧 1,065
MA0329001 Quantum 远程I/O电缆 F 接头(10个/盒) 1,747
490RIO00211 Quantum F 连接器 用于 RG-11(6个/盒) 1,348
520480000 Quantum 右角度 F 适配器 用于半刚性电缆 101
520614000 Quantum F-to-BNC 适配器 用于 RG-11 电缆 90
600513000 Quantum BNC 终结电阻 693
490RIO00400 Quantum RG-6 同轴电缆剥线工具 1,510
490RIO0S411 Quantum RG-11 同轴电缆 剥线工具 1,193
490RIO00406 Quantum 替换刀片 RG-6 448
490RIO00411 Quantum 用于490RIO00400 同轴电缆脱膜工具的RG11替代刀片 448
490RIO
600544000 Quantum 用于 RG
600558000 Quantum 电缆切割钳 911
Quantum Distributed I/O (Modbus Plus) 分布式I/O
140CRA21110 Quantum DIO 站适配器和电源,115/230 VAC,独立,
140CRA
140CRA21120 Quantum DIO 站适配器和电源,24 VDC,独立,
140CRA
140CRA21210 Quantum DIO 站适配器和电源,115/230 VAC,独立,
140CRA
140CRA21220 Quantum DIO 站适配器和电源,24 VDC,独立,
140CRA
Quantum Communication Module 网络通讯模板
140NOE77101 Quantum Quantum Ethernet 10/
140NOE
140NOE77111 Quantum Quantum Factorycast Web Server Ethernet 10/
140NOE
140NOM21100 Quantum MB+ 网络适配器,1MB, 1MB+,单电缆 11,248
140NOM
140NOM21200 Quantum MB+ 网络适配器,1MB, 1MB+,双电缆 15,747
140NOM
140NOM25200 Quantum MB+ 网络适配器, 光纤接口, 1 CH 17,996
140NOM
140NWM10000 Quantum FactoryCast HMI 35,516
140EIA92100 Quantum Quantum AS-i MASTER模板,1通道 8,560
140EIA
140NOA62200 Quantum Interbus 主站模块 17,999
140ESI06210 Quantum ASCII 串行通讯模块,RS232,2通道 15,425
140ESI
Quantum Communication Accessories 网络通讯及附件
490NAE91100 Quantum Profibus DP Tap带Host口 6,126
467NHP81100 Quantum 467 NHP 811 00-PC/DP包 16,710
490NAD91103 Quantum Profibus 连接器 终端 634
490NAD91104 Quantum Profibus 连接器 线间 390
490NAD91105 Quantum Profibus 连接器 线间 + 终端 982
490NAC72100 Quantum MB+ 避雷装置 3,886
490NRP25300 Quantum 光纤中继器,单光口,Modbus Plus 16,710
490NRP25400 Quantum 光纤中继器,双光口,Modbus Plus 21,730
490NTRJ11 Quantum TF可配置转换器,CORD 393
490NAA21302 Quantum MB+ SUPPER 网络电缆,500英尺 16,550
490NAA27101 Quantum MB+ 电缆,10英尺 1,087
490NAA27102 Quantum MB+ 电缆,500英尺 5,359
490NAA27103 Quantum MB+ 电缆,1000英尺 10,640
490NAA27104 Quantum MB+ 电缆,1500英尺 16,076
490NAA27106 Quantum MB+ 电缆,5000英尺 40,947
990NAD21110 Quantum MB+ 站电缆,
990NAD21130 Quantum MB+ 站电缆,
990NAD23000 Quantum MB+ TAP接头 300
990NAD23010 Quantum MB+ TAP接头, mounting plate 2,365
990NAD23011 Quantum 线缆终结器 323
990NAD23020 Quantum MB+ TAP接头, DIN rail 1,718
990NAD23021 Quantum MB+ TAP接头, mounting plate 1,735
990NAD23022 Quantum MB+ 线缆终结器 763
990NAA21510 Quantum 耐用型带Modbus Plus接头编程电缆(10 英寸) 646
990NAD21810 Quantum MB+ 支线电缆,
990NAD21830 Quantum MB+ 支线电缆,
990NAD21910 Quantum MB+ 支线电缆,
990NAD21930 Quantum MB+ 支线电缆,
990NAD23012 Quantum MB+ 加固型接头DIN导轨安装套件 321
ASMBKT085 Quantum MB+ LINE 接头 533
ASMBKT185 Quantum MB+ 终端接头 1,110
ASMBPL001 Quantum MB+ 接头工具 2,045
NWBM
NWBM85D008 Quantum MB+ 网桥/多路转换器, 2 MB+, 4 RS232, Modbus,19'in Rack, 24/115 VDC,Panel 27,293
NWBM85S232 Quantum MB+ 网桥/多路转换器,2 MB+,可编程,4 RS232,Panel 18,768
NWBM85S485 Quantum MB+ 网桥/多路转换器,2 MB+,可编程,4 RS485,Panel 22,830
NWBP85002 Quantum MB+ 网桥,双电缆,115/230VAC, Panel 22,836
NWRR85001 Quantum MB+ 中继器,单电缆 16,153
Quantum Programming Cable 编程电缆
990NAA26320 Quantum 编程电缆,RS232,
990NAA26350 Quantum 编程电缆,RS232, 50 英尺 1,783
UNYXCAUSB033 Quantum Unity USB 编程电缆 1,980
110XCA28201 Quantum 连接电缆, 用于 PC RJ45 接口
110XCA28202 Quantum 连接电缆, 用于 PC RJ45 接口
110XCA28203 Quantum 连接电缆, 用于 PC RJ45 接口
Quantum Cablefast Connection Cablefast 预接线系统
140CFA04000 Quantum CABLEFAST, 通用连接块, 直头连接 951
140CFB03200 Quantum CABLEFAST, 数字输入块, 单独保险 2,927
140CFC03200 Quantum CABLEFAST, 数字输出块, 成组保险 1,762
140CFD03200 Quantum CABLEFAST, 数字输入块, 2线或3线, 单独保险 2,340
140CFE03200 Quantum CABLEFAST, 数字输出块, 单独保险 2,927
140CFG01600 Quantum CABLEFAST, 大功率数字 I/O 块, 单独保险 1,987
140CFH00800 Quantum CABLEFAST, 模拟量输入块, 带保险 1,762
140CFI00800 Quantum CABLEFAST, 模拟量输入块, 无保险 999
140CFJ00400 Quantum CABLEFAST, 模拟量输出块, 带保险 1,057
140CFK00400 Quantum CABLEFAST, 模拟量输出块, 无保险 704
140CFU00600 Quantum CABLEFAST 保险, 1/16 AMP 309
140CFU08000 Quantum CABLEFAST 保险, 0.8 AMP 295
140CFU40000 Quantum CABLEFAST 保险, 4 AMP 295
140CFX00110 Quantum CABLEFAST 端子块接地条, 10位置 121
140CFX00210 Quantum CABLEFAST 保险备用跨接器 295
140XCA10206 Quantum CABLEFAST电缆, 大电流, 50针D型,
140XCA10215 Quantum CABLEFAST电缆, 大电流, 50针D型,
140XTS00203 Quantum CABLEFAST电缆, 带 QUANTUM I/O 端子,
140XTS00206 Quantum CABLEFAST电缆, 带 QUANTUM I/O 端子,
140XTS00209 Quantum CABLEFAST电缆, 带 QUANTUM I/O 端子,
140XTS00212 Quantum CABLEFAST电缆, 带 QUANTUM I/O 端子,
140XTS01203 Quantum CABLEFAST电缆, 大电流, 带 QUANTUM I/O 端子,
140XTS01206 Quantum CABLEFAST电缆, 大电流, 带 QUANTUM I/O 端子,
140XTS01209 Quantum CABLEFAST电缆, 大电流, 带 QUANTUM I/O 端子,
140XTS01212 Quantum CABLEFAST电缆, 大电流, 带 QUANTUM I/O 端子,
140XTS10206 Quantum CABLEFAST电缆, 大电流, 带 I/O 端子,
140XTS10215 Quantum CABLEFAST电缆, 大电流, 带 I/O 端子,
Quantum Terminal Block and Accecories 端子连接器及附件
140XCP20000 Quantum I/O 模块标签 228
140XCP40100 Quantum 19 英寸 前导轨安装架
140XCP40200 Quantum 19 英寸 前导轨安装架
140XCP50000 Quantum 空槽模块, 无端字条 389
140XCP51000 Quantum 空槽模块, 带悬挂门 447
140XCP60000 Quantum 端子条跨接器 281
140XCP90000 Quantum RAM电池备用模块, 用于ESI061和EHC105 2,789
140XCP
140XSM00200 Quantum 开关量输入模拟器, 用于DAI540或DAI740 3,747
140XSM01000 Quantum 模拟量模拟器, 2个电位器,用于AMM090 11,700
140XTS00100 Quantum 40点模块端子条, IP20 740
140XTS00200 Quantum 40 点模块端子条 355
140XTS00500 Quantum 7点端字条, IP20 344
140XTS33200 Quantum 40 点模块端子条, 本安型蓝色 (IP20 级) 934
990MCO00065 Quantum 塑包光纤,
990MCO00095 Quantum 塑包光纤,
990MCO00105 Quantum 塑包光纤,
990MCO00115 Quantum SERCOS光纤电缆,
990MCOKIT00 Quantum 用于安装光缆的设备 具体价格请联系Motion
990MCOKIT01 Quantum 光缆 和 SMA-型连接器 套件 具体价格请联系Motion
990XCP98000 Quantum Quantum CPU 电池 389
990XTS00300 Quantum B200 转换接头 886
110XCA20300 Quantum 适配器 RJ45 到 RS232
- 电话:0591-83778301
- 传真:0591-83781315
- email:jinhuang_1779@sina.com
